Results 1 to 7 of 7
Thread: Bad to leave the chlorinator "on"
    Mar 2016
    Tampa, Florida
    93
    Is it bad to leave the chlorinator "on" all the time even though if I understand correctly it is only generating chlorine when the pool pump is running? I know I have read several times these cells have a specific life span so I want to make sure technically being on wouldn't count towards that life span.
    I ask because I am still batting Omnilogic glitches and the one schedule of many that does not seem to reliable turn on is the chlorinator. Therefore, until the chlorinator schedule and other Omnilogic glitches are worked out I was hoping to just leave the chlorinator in the "on" state and adjust the percentage so that I generate the correct amount of chlorine based on my main pull pump run time.
    Gallons 13,860 / IG Pebble / Hayward OmniLogic / Hayward Swim Clear Filter / Hayward EcoStar / Hayward TriStar VS (for water features) / Hayward HeatPro Heat Pump / Date of build 3/11/16 / Other features: Spa / Hayward Colorlogic LED lights (2 in pool / 1 in spa) / Pentair LED Bubblers (2 one on each sun shelf) / Pentair Color Cascade Laminars (4 around pool) / Taylor K-2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Re: Bad to leave the chlorinator "on"
    Yes, off is better. It can explode. Here are a couple of exploding SWG threads.
    New Member Swade
    SWG cell explosion
    My VS pump is wired to the breaker and my SWG is wired to a timer. I make SURE to check the time periodically and I make SURE that the SWG only comes on inside the window that the pump runs.
    The rated number of hours do only include hours when it is generating.
    Mar 2016
    Tampa, Florida
    93
    Bad to leave the chlorinator &quot;on&quot;
    Thanks, interesting reads. I am not sure how the builder wired the SWG but I plan to find out.
    My Omnilogic system manual does state:
    "Chlorinator Setting - The OmniLogic can only generate chlorine while the filter pump is operating. Set the percentage of run time that you desire chlorine generation."
    "For the chlorinator to be operating, several conditions must exist: the filter pump must be running, the flow switch must detect flow, the chlorinator setting must be greater than 0%, the water temperature at the cell must be between 50 F and 140 F (superchlorinate will run under 50 F except during freeze protection), and the salt level must be within the operating range. If any of these conditions are not met, the diagnostic screen will show that the chlorinator is off. Also, depending on the chlorinator setting, the OmniLogic may be in between cycles and the chlorinator is at rest (cell current shows 0.00A). To force the start of the new cycle, you can touch the Reverse Polarity button."
    Perhaps the system automatically avoids this issue (generation of chlorine/gases) when the pump is not running???
    JoyfulNoise's Avatar
    May 2015
    13,204
    If you have a power distribution center with your automation panel (most do), then the SWG should be wired so that it is only energized when the main pump is running. You should never rely on the SWGs internal flow switch to act as the ON/OFF button although a lot of (really bad) PBs will do it that way.
    Matt
    DFW, TX
    24,492
    I don't know enough about the Omnilogic to comment on that. The problems I have seen are related to relying on the flow switch to shut off the cell. Which may be what the Omnilogic relies on.
    Mar 2016
    Tampa, Florida
    93
    Walked outside to the Omnilogic wall panel. To test. When the chlorinator is on, and the pump is not running, the chlorination symbol is not activated. But, when I turn the pump on, the chlorination symbol starts to spin.
    I think at least at this level, when the chlorinator is on the system is not generating chlorine until the pump is running.
    May 2016
    Phoenix AZ
    128
    If the SWG is on when the pump is not running, things can go wrong. A flow switch can fail in more than one way. If the flow switch fails to shut off when the pump is not running, your SWG can (literally) explode. I had this happen a few years ago - it is not a pretty sight.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
