Thread: Advise Requested - New to VS pump - run time suggestions
    Jun 2016
    Central Valley, CA
    31
    I have read and read and read. I understand its really a function of trial and error. I am attempting trying to reduce the trial/error period and am hoping someone can suggest a good starting point for my Hayward Tristar VS run time/RPM program.
    This is a new pool, PB initial startup was 7/15/16. My previous pool was a single speed main pump, pressure side cleaner & booster pump and a 3rd water feature pump. It certainly was NOT power friendly but I had that all figured out. This pool is a VS with Suction Side cleaner and a whole new learning curve for me.
    Pool Details...
    16' x 32' IG Pool
    ~20k gallons
    White Plaster
    Hayward Tristar SP3202VSP
    Pentair 60 sq ft DE Filter
    Hayward Navigator Pro Suction Cleaner
    From the pool 2" line from suction cleaner and 2" line from Skimmer/Main Drain
    - These are merged with a Jandy valve into a single 2" input to the pump.
    To the Pool is a single 2" line out of DE filter that is reduced to (3) 1.5" return lines in the pool.
    The pool builder's initial program was 5 hrs of full speed. The pool looks great, but I am not getting any advantage of the VS pump so I would like to reprogram with help from all the experience here.
    Any suggestions are much appreciated.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Advise Requested - New to VS pump - run time suggestions
    I run mine at 1100 rpm to filter, skim and make chlorine with the SWG. It uses 150 watts at 1100 rpm. Most folks can run 1000-1500 rpm 4 to 6 hours per day. Some split it to half AM and half PM to keep the pool skimmed better. Some run it 12 hours a day because the electricity consumption is minimal. At 10.25c/kWh it costs about 6 bucks a month run 12 hours a day at 150 watts.
    Jun 2016
    Central Valley, CA
    31
    Thank you pooldv, I really appreciate it.
    In some really quick tests I ran, <=1500 RPM doesn't produce enough suction for the Navigator, so I'll need to run it a bit higher than that for some time at least.
    Here is my current setting, let me know if you see any issue or concerns...
    0500-0700 = 3000 RPM (essentially to run the Navigator)
    0700-0900 = 1400 RPM (skim & filter)
    2100-2400 = 1400 RPM (skim & filter)
    We do have several deck spitter on valves that the kids like to run whenever they swim, which is essentially daily. When those are on I have programmed a button for them to push that runs the pump at 1000 RPMs to run the spitters. This basically provides some additional filter time too, although I think the 7 hours should be plenty.
    16' x 32' IG 20k Gallon
    Traditional White Plaster
    Hayward Tristar VS Pump
    Pentair 60 Sq. Ft.
