Page 1 of 14 123411 ... LastLast
Results 1 to 20 of 269
Thread: The Return of the Pool That Just Won't Die
    Jul 2016
    Marcellus, NY
    323
    First off, I'd like to thank CJ for all of his excellent advice in my last thread. His patience with me and my meltdowns is that of no mere mortal.
    So at this point, I've drained the pool to a ft and refilled. I have my pump going. I also have my new pool measurement of 21ft diameter and 4ft deep (haven't done the math yet on gallon size, but I will once I find that calculator again). So that probably explains why things went pear shaped last time.
    But hey, after the refill we are now dealing with a greenish blue pool instead of just a green one, so...progress?
    So what comes next? I'm assuming:
    1. Let the pump run for a while.
    2. Do all the tests and get our numbers.
    Then I can determine the amount of stabilizer + bleach I need to continue to slam?
    10,400 Gal Pool, Hayward Dreamline Sand Filter Model S190TSCPE, Hayward Power-Flo LX Pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    Re: The Return of the Pool That Just Won't Die
    Pool Math is you friend-look up ^^^^ there. See the blue oval that says Pool Math? There is where you go to figure out your size in gals. Put the new info. in your siggy so it will stick there.
    Do you have the SLAM info bookmarked or printed out? If not do so now. If not go to the table of contents on the left hand side or the home page and you will see it under S for SLAM
    Get some bleach in ASAP to get that pool clear!
    Were you able to get any junk off the bottom of the pool? Do you have a pool net called a rake? It is a net with a deep pocket. It is for scooping stuff off the bottom of the pool or when you have lots to stuff on the top.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    What she said !!
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2016
    Marcellus, NY
    323
    Bleach in ASAP? Shouldn't I test first? I don't know how much to put in. But hey, I'm all for throwing a couple jugs in.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Alright, welcome back.
    You can go ahead and plan on adding 30 ppm of CYA/stabilizer in a sock because there is never any in tap water. The rest will need to wait for some test results.
    Yes, 3 ppm of bleach right away.
    More here on how to add CYA and other chems to your pool, Pool School - Recommended Pool Chemicals
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Thanks for the kind words guy.. I appreciate it.
    This is why you tested your fill water... I think it was 1.5 fc and .5cc. Use that info to find how much bleach to add until you are full up. Use pool math to find out how much based on your volume
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Jul 2012
    Tallahassee, FL
    30,383
    Quote Originally Posted by Guybrush3pwood View Post
    TEST first and now please. Use pool math up above to find out how much to put in to reach your SLAM level using the FC/CYA chart found inside the SLAM link you just found (I hope).
    You ALWAYS test before you add ANYTHING! That is pool care lesson 1 for TFP. Good job learning that one and asking before you put any bleach in!
    Jul 2016
    Marcellus, NY
    323
    Roger that. Thanks everyone. My only concern is that there is no sun right now...completely overcast. So I can't test CYA if I understand correctly. Without knowing CYA, can I still determine how much bleach to put in?
    Jul 2012
    Tallahassee, FL
    30,383
    VERY good question!
    Lets do this just for this time ONLY to give us a ball park figure as I think your CYA is going to be low.
    Do you have a very bright light somewhere in the house? Mine is the light in my stove hood. When I test my CYA there I am about 5 ppm off so lets say YOU will also be about 5 off.
    Do the CYA test FACING the bright light. Holding the tube at your tummy and doing the pour and glance method.
    REMEMBER this is ONLY for this time just go get your SLAM started tonight. This is NOT the ideal way but will do for a ball park.
    Now go test and let us know what you find on your levels.
    Oh and use Poo Math to update you pool size (gals.) please.
    Jul 2016
    Marcellus, NY
    323
    Poo math?! Ack! I know my water is gross, but come on. It's not that bad. I should know, I drank some. ��
    Jul 2012
    Tallahassee, FL
    30,383
    You are BAD! EWWWWWWWWWWWWWWW LOL I am going to leave it just like it is so there!
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    I'm going to guess zero... shouldn't be any cya in tap water but you never know
    13500 gal
    Jul 2012
    Tallahassee, FL
    30,383
    Yeah but he did have about 1 foot of water left so I don't want to him over shoot.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    I'd like to start off by saying that I'm somewhat behind concerning your issues as I have yet to read your other post, but I think it's best to update everything anyways so let's start with the basics.
    Can you please do us three favors.......
    1. Can you please post a CURRENT set of test results using your own test kit. Please list the following,
    • FC
    • CC
    • CYA
    • pH
    • TA
    • CH
    2. Can you please post a current photo of your water. This will help us see just how much "work" we need to do.
    3. How are you viewing TFP? Are you on a cell phone using the mobile version of the forum? Tapatalk?? Desktop version??? By knowing how you are viewing TFP will help us assist you further in navigating the forum.
    Once we get these items addressed we can start preparing a plan to help you clear your pool.
    Jul 2016
    Marcellus, NY
    323
    Ugh, I typed out all the answers but my phone died. Lost all my results too. I'll have to start over.
    Jul 2012
    Tallahassee, FL
    30,383
    OH no! Lesson 2 of TFP keep a log of your test results. I have a one of those small notebooks I keep my log in. It helps in the long run. You will start to see the pattern of your pool.
    Jul 2016
    Marcellus, NY
    323
    Quote Originally Posted by kimkats View Post
    I like that idea. Will definitely do.
    Ok, so:
    CL - 5
    BR - 10
    ph - 7.2
    alk - 90
    FC - 6.5
    CC - 1
    TC - 7.5
    CYA - 20...or less?
    Didnt do calcium hardness because I don't have a masonry pool, and the results were low on the tap water test, but if you guys think I should do it, I can.
    Viewing mostly on my phone. My PC is still packed away.
    Picture. Much more Blue than green this time around.
    Could clean the bottom a little while it was draining, but not much. I was syphining it (hence getting to drink it) and didn't want to mess with it much. However, the leaf catcher has been absolutely amazing and I've been able to pull up a lot with it. I figure I can vacuume while the slam is going on.
    Hopeully that answers everything?
    Oh, about the CYA. It was hard to say. At 20, I could barely see it at all, butttttt I could still see it none the less. So I wouldn't say 0, but not quite 20 either?
    Pool is 10,400 gallons. Yeah, probably why things went wrong.
    Jul 2012
    Tallahassee, FL
    30,383
    Next job while I work up the second job............change your siggy to reflect the 10,400 gals please.
    Jul 2016
    Marcellus, NY
    323
    Done and done.
  20. Back To Top    #20
    Jul 2011
    Eastern Ohio
    7,075
    Next question for you.........
    Have you added any CYA in the last two or three days??
