Intex pump/sand filter upgrade
Schnozz
440
Charter Oak, California
Thinking about upgrading from the current 1/2 HP 2100 gph pump/sand filter set up to
the 3/4 HP 2800 gph or the 1 HP 3000 gph. I believe either one will connect to the current setup without the need for other fittings.
Trying to to get better circulation for fewer dead spots, trying to get more filtration with larger sand filter and trying to make vacuuming a bit less tedious.
The 1/2 HP has been a workhorse, but a larger pump/sand filter would I think be better in the long run...
what sayeth all ya'll?
Piolin....Or anyone with experience in this area....
Are you able to connect the new Intex 3000 GPH pump/filter in place of the smaller Intex pump/sand filter that came with the pool without additional adapters or connectors?
Thanks for taking the time Piolin.....
8,400 gal 3K GPH pump, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
The corner stone of TFP
Pool School - Chlorine / CYA Chart
My oversized slab is going in next month. So my pool will be down for about 2 weeks..It looks like the 2" of foam goes under the legs as well? Do the legs cut /sink into the foam?
Thanks for responding......It's been very helpful
Bob
The foam that I use was the only available here, from home Depot, yes the legs cut into the foam a little, in all legs so the level stay the same, but if you can find the extruded pink or blue 3/4" foam that people recommend here you will do better
JeffChap: That same pump/filter is on sale at Walmart for $199.99. WOOHOO!! I may go that way instead of the 3000GPH Intex
The only adapters necessary to connect it to your Intex pool were the ones you purchased at Leslies?
Thanks, Bob (AKA Schnozz)
