Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Intex pump/sand filter upgrade
    Jul 2015
    Charter Oak, California
    273
    Thinking about upgrading from the current 1/2 HP 2100 gph pump/sand filter set up to
    the 3/4 HP 2800 gph or the 1 HP 3000 gph. I believe either one will connect to the current setup without the need for other fittings.
    Trying to to get better circulation for fewer dead spots, trying to get more filtration with larger sand filter and trying to make vacuuming a bit less tedious.
    The 1/2 HP has been a workhorse, but a larger pump/sand filter would I think be better in the long run...
    what sayeth all ya'll?
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Intex pump/sand filter upgrade
    I have the same pool you have, and with the 3k pump and the 16" sand filter we are very happy
    8,400 gal 3K GPH pump, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    Jul 2015
    273
    Piolin....Or anyone with experience in this area....
    Are you able to connect the new Intex 3000 GPH pump/filter in place of the smaller Intex pump/sand filter that came with the pool without additional adapters or connectors?
    Thanks for taking the time Piolin.....
    Bob (AKA Schnozz)
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I hard plumbed with PVC, but before that, I was able to connect the 3K pump just fine... But if you can put PVC it will be much better
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Go all the way with 1 1/2" PVC and you will have a better flow
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Don't forget to install a Skimmer.... 😊
    Jul 2015
    273
    You did nice work...how far away from the pool is the pump and filter? It looks like you're on a concrete slab as well?
    Bob (AKA Schnozz)
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Not far, less than 10 feet, yes, 4 Inches Concrete slab, and 2 Inches foam pad
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    The most important thing is you need to have a level ground, and in Florida with the coral ground, was easy for me to place a LEVEL Concrete pad ($1,000)
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I oversized my pad, bc eventually I will grow to a bigger pool 32x16 Intex pool
    Jul 2015
    273
    My oversized slab is going in next month. So my pool will be down for about 2 weeks..It looks like the 2" of foam goes under the legs as well? Do the legs cut /sink into the foam?
    Thanks for responding......It's been very helpful
    Bob
    Bob (AKA Schnozz)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    Here's my pump upgrade thread too. I've been very pleased with this pump.
    New pump arrived today
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    The foam that I use was the only available here, from home Depot, yes the legs cut into the foam a little, in all legs so the level stay the same, but if you can find the extruded pink or blue 3/4" foam that people recommend here you will do better
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Also if you decide to go with the skimmer, I also will go a little higher in the cut, so you will not lose any water level
    Jul 2015
    273
    You guys are great. Thanks for the help...This old guy thanks all ya'll...
    Bob (AKA Schnozz)
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Good luck and keep posting pictures of your rebuild when you start...
  20. Back To Top    #20
    Jul 2015
    273
    JeffChap: That same pump/filter is on sale at Walmart for $199.99. WOOHOO!! I may go that way instead of the 3000GPH Intex
    The only adapters necessary to connect it to your Intex pool were the ones you purchased at Leslies?
    Thanks, Bob (AKA Schnozz)
    Bob (AKA Schnozz)
