Thread: Spa draining when trying to use it
    Sep 2013
    San Diego, California
    21
    Hi Guys
    I have an inground spa/pool. I haven't used the spa for almost a year. Today I noticed that when I try to heat the spa the water drains from it. I assume it's draining into the pool.
    Can anyone suggest trouble shooting action?
    Many thanks
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    5) Flow rate of filter; 120
    Location - San Diego, California
    May 2016
    Phoenix, AZ
    167
    Re: Spa draining when trying to use it
    I would assume a valve is wrong. You should probably have two valves to turn. One directs pump output to pool or spa. The other changes suction from pool or spa. Sounds like you have suction for spa and output to pool.
    13k Pebbletec Pool/Spa, Hayward Ecostar, SGS Breeze 540 SWG, Pentair C&C 420 cartridge, Pentair MasterTemp Heater, Caretaker system, TF-100 & Taylor K1766 test kits
    Jan 2012
    340
    Assuming you have an automation system, you could have a bad pressure side actuator.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Sep 2013
    21
    ok I had the actuator valve replaced at the time and now it's doing the same darn thing Wonder if it's under warranty?
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
