Thread: How do I shut off power to the pump timer?
    Oct 2013
    Fort Worth, Texas
    19
    Hi everyone-
    I've been having issues with my pump timer not working. The cogs in the "visual motor check" window are moving. I've already tried changing the trippers and that didn't help. So I bought a new timer motor. I've read instructions on how to change it and the very first thing is to always shut off the power (duh). I opened the small box next to the timer box, but it didn't look like a normal breaker like I was expecting. It says "clutter control" along with the nice "DANGER HIGH VOLTAGE" warning. image.jpg
    I'm guessing I just turn the knob to "0", but obviously I want to make sure. I'm including a pic, so hopefully that will help. Thanks!
    ~20,000 gallon, plaster, sand filter, not currently sure of the pump size or flow rate of the filter, Forth Worth, Texas
    **clearly I'm a newbie, so please forgive my ignorance--I will update as I find out more about the equipment that we have**
    Oct 2013
    Fort Worth, Texas
    19
    Re: How do I shut off power to the pump timer?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I expect that box is something like freeze protection. You'll need to look at your panel or a subpanel for the breaker for your pump.
