Thread: Cyanuric Acid differences?
    Jul 2016
    San Diego, California
    1
    In previously searching the site, I was unable to find a thread on cyanuric acid comparisons. Is there any difference from one manufacture to the next? The prices greatly vary for a product labeled 100% cyanuric acid. Are you really paying for a name brand or is it all the same? The price on liquid versus dry seems to be much higher. Can anyone tell me the difference asides from the obvious form? Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Cyanuric Acid differences?
    Welcome to the forum!
    The only difference in dry CYA is how quickly it dissolves. I usually get mine from either WalMart or Lowes. Both seem to dissolve pretty quickly.
    Mark
    JoyfulNoise's Avatar
    May 2015
    13,176
    Also note that liquid CYA is typically only 30% CYA and usually costs more. So for liquid CYA you are definitely paying more for less.
    Matt
    May 2015
    13,176
    I use BioGuard Stabilizer-100 and it's always worked fine for me. Typically dissolves within a few hours when hung in a nylon in front of a return.
    Matt
