Thread: Pool timer
    Jul 2016
    Shippensburg, Pennsylvania
    3
    Pool timer
    I turn my pool timer on and my circuit breaker flips off. Is this because it's wet. We had a huge rain yesterday and my door to the timer was open.
    Kim
    Jul 2015
    Central Valley CA
    1,107
    Re: Pool timer
    welcome to the forum
    The rain very well may be the cause especially if the breaker is a GFCI. Can you post a picture of the timer and the breaker panel it will help with suggestions. First thing to try is do what you can to dry things out.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2016
    3
    Re: Pool timer
    The breaker is a GFCI and here is a picture of my timer.
    Kim
    Jul 2015
    Central Valley CA
    1,107
    Re: Pool timer
    Picture is not showing up. Is the timer a dial type or digital? Assuming it is not raining I would open the door at the very least and you may want to go as far as removing any wire covers see if you can see any moisture. (Breaker off of course)
    Jul 2016
    3
    Re: Pool timer
    It is a dial type. I have the door open trying to dry it out. I'll go ahead and remove the cover to see if there is any moisture. Thank you!
    Kim
