Thread: TA question this morning
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    My TA is at 50, but PH is holding 7.5-7.6 consistently. Any reason to raise TA to recommended level of 60-80? I've used about 20 ounces of MA the whole month of July.
    FC- 7
    CC- 0
    PH- 7.6
    TA- 50
    CYA- 70
    Water Temp- 82
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: TA question this morning
    No, definitely not. Leave it at 50. Most folks find PH is stable between 50 and 70. If you notice your PH fluctuating up and down then raise it 10.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Thanks.......That's what I was hoping to hear!!
    Mark
