Results 1 to 14 of 14
Thread: Krystal Clear Saltwater System CG-28669
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    My Old Saltron retro died
    My wife wants to keep the SWG.
    So this claims to go up to 15000 Gallons
    Im a little leary
    Looking for a good replacement system. maybe this will get me thru the rest of this season.
    any advice is appreciated.
    Any real experience with this unit on a larger AGP?
    I see folks using them on smaller pools
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Krystal Clear Saltwater System CG-28669
    I have one, so far I like It... It was at Amazon for $99, last time I checked it was $300...😕
    8,400 gal 3K GPH pump, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    Jun 2016
    Boca Raton,fl
    39
    I have two in series. Been working great for two months. See http://www.troublefreepool.com/threads/119039-Intex-Salt-Water-Generator-(SWG)-for-in-ground-pool-(IGP)-Model-ECO-8110-28669EG
    I have been running both swg 6 hours 3 hours a day to maintain chlorine level. Originally purchased two swg for $100/piece total $200 for both. I do not expect it to last as long as a $900+ system, but It will pay for itself in less that one year time. Without the SWG, I would be dumping $45/month of chlorine/chemicals during the hot south Florida summer months. Amazon selling the unit for $126 right now.
    Also use this chart to compare the chlorine output of your old unit vs the Intex and others:
    http://www.discountsaltpool.com/Salt...Comparison.php
    16000 gal In-Ground , American Commander 150 Filter, Hayward pump ,
    Two Intex Saltwater System CG-28669 in series, screened in pool,baracuda g3
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by paulnx View Post
    I have been running both swg 6 hours a day to maintain chlorine level. Originally purchased two swg for $100/piece total $200 for both. I do not expect it to last as long as a $900+ system, but It will pay for itself in less that one year time. Without the SWG, I would be dumping $45/month of chlorine/chemicals during the hot south Florida summer months. Amazon selling the unit for $126 right now.
    Thanks
    I think Ill try one for the rest of the summer
    You post helped
    --- Greg----
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    I used one for several years until lightning took it out two weeks ago. Of course lightning will take out almost everything. The biggest complaint I had was that it had to be rest after any power blip. Vacations are especially vulnerable times if no one is there to reset it. For the money and the remainder of the summer, it is an economical option. You DO NOT want the version with the copper anodes.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by Vickery View Post
    what wrong with the copper anode?
    --- Greg----
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    The unit you are asking don't have copper bar, it was used by Intex in an outdated SWG, but basically cause stains in the pool, hair, and nails
    Jun 2016
    Boca Raton,fl
    39
    the "how many hours to run" settings are retained after power loss on this newer model. I have my Intex SWG wired to pump timer (ie powers on when the pump is running)
    Makdaddy's Avatar
    Jul 2012
    119
    So got it installed Sunday
    GFI keeps tripping, Tried another outlet still trips.even with the unit turned off
    Waiting to hear back from Intex
    I heard these GFI had issues , some folks just put a plug on it?
    I have GFI at the breaker , so that wouldnt be an issue for me and safety.
    --- Greg----
    Jun 2016
    Boca Raton,fl
    39
    Never had problem like that with mine. Sounds like the GFCI is defective or you actually have an issue (water in GFCI etc, shorted at the unit). Wouldn't be easier to return it and get a new one?
    Looks like others had simliar issues
    http://www.troublefreepool.com/threads/94132-CS8110-Intex-unit-GFCI-does-not-work
    http://www.troublefreepool.com/threa...will-not-reset
    JC67's Avatar
    Jun 2016
    Byrnes Mill, MO
    3
    I put a regular plug on mine gfci plug failed first week.
    Is it OK to start and stop just on pump timer? Manual says pump should be running some before and then after swcg. Obviously if it doesn't get flow it just goes into fault mode and recovers automatically when flow is detected. I'm putting a new pump timer in this weekend and been debating plugging this into same or using a second timer that allows for some offset.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    If you watch it carefully after you turn it on, you'll notice that it takes about 20 seconds or so before it really kicks on and starts generating. I've had my pump and SWG on the same timer for years with no problems.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Makdaddy's Avatar
    Jul 2012
    119
    Amazon is sending a replacement
    I didnt want to cut the GFI out, It would have voided the warranty
    SO we will see what happens next week
    --- Greg----
    Makdaddy's Avatar
    Jul 2012
    119
    WOW
    Amazon sent me a used unit for replacement
    I couldnt believe it
    I ended up cutting off the defective GFI and put a regular plug on it. New unit works
    Will be sending the used unit back to Amazon
    --- Greg----
