Thread: Pool bottoms
    Jul 2016
    Mechanicsville MD
    5
    Pool bottoms
    Going to put an abg pool in and need help deciding what bottom to use?
    21x43
    Pool Crete?
    Vermiculite?
    sand?
    What's the best for diy?
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: Pool bottoms
    In the past for in ground pools, companies used vermiculite (which supposedly move around a little bit). They started using a stronger base (sand/cement mix). If no one is jumping and doing cannonballs from a ladder or tree, the Pool Crete (which is probably a harder base is best). If not, then stick with the sand or vermiculite, which is a softer base.
    I believe there is no best or right choice, just different options. Good luck and keep us posted. Once completed, please add your signature so in the future if you have any questions, we can be of help.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Pool bottoms
    I recall seeing some AGP builds where the owner put some sort of heavy duty foam core base down in large panels, using gorilla tape at the seams. Does this ring a bell with anyone?
    Jul 2016
    Mechanicsville MD
    5
    Re: Pool bottoms
    I was thinking of using the foam then a gorilla pad?? I am reading that once pool structure is up you need 2" of "bottom". Trying to decide on foam or sand??? Anyone have advice?
