Thread: Adding chemicals- stabilizer
    Jul 2016
    Creston, Iowa
    7
    Hi there, I have had my new pool up and running for a week now, I am mildly obsessed with testing not sure if I am testing too frequently by testing every other day. Pool water is clear looks great, I have a 2hp sand filter on an AG 18x33x54 vinyl lined Pool and my test was
    FC .5
    CC .5
    TA 110
    pH 7.9
    CH 90
    CYA 0
    I entered info into pool math and added 78 oz liquid bleach (8.25%), need to also add some pH Minis 17oz, and it says 84oz stabilizer, I have dry so was going to use sock method. Also need 324 oz calcium chloride?! Planning on adding all 30 min apart
    I have 2 questions 1- can we still swim with sock of stabilizer in skimmer, and 2- do I really need that much Calcium Chloride?
    thanks!
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Adding chemicals- stabilizer
    Get some bleach in there STAT, and hang a sock of CYA immediately after or you'll be asking for help to get rid of algae soon. Really. Squoosh the sock now and then to speed up the process of dissolving. White milky water will come out, that's normal.
    Skip the calcium unless you have a heater that needs it. Vinyl pools don't need calcium otherwise.
    Drop the pH with muriatic acid (cheaper, better....but if you already bought the pH minus, c'est la vie)
    Yip
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, you can swim while adding CYA I swim around with the sock to help it dissolve faster.
    +1 to more chlorine pronto.
    Jul 2016
    Creston, Iowa
    7
    Thank you everyone you are the best!
    Jul 2008
    Seacoast, NH
    250
    BTW, I test FC, CC, and pH every day. The other stuff you can test way less frequently.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
