Results 1 to 18 of 18
Thread: Pool water turning finger nails green
    May 2015
    Arnprior, Ontario Canada
    21
    Copper in my pool water. How do I remove it?
    Intex Ultra frame 16'x48" above ground; Intex 2800 GPH Sand Filter Pump; Intex Krystal Clear Saltwater System Model# CG-28669; Hayward H100ID1 gas pool heater.
    JoyfulNoise's Avatar
    May 2015
    13,217
    Re: Pool water turning finger nails green
    The only way to get rid of copper is to drain and refill. You need to ditch that Intex ionizer system as it constantly adds copper to your water. TFP does not recommend using copper ionizer systems for this very reason.
    Matt
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Best way would be to drain and refill.
    Pool School - Metals in the Water and Metal Stains
    Do you know how you got the copper in there?
    May 2015
    21
    I'm thinking like what "JoyfulNoise" mentioned in his comment below, the saltwater generator. This is my third year with it and it has a slow leak in it. My next question is, do I have to dump all of the water in the pool, can I fix this with dumping half of it? Thanks in advance for any/all the help.
    May 2015
    13,217
    That model of Intex SWG has an "ionizer" cell in it - basically a copper rod that has a voltage applied to it to cause it to dissolve copper metal ions into your water. The problem with copper is that it is a great algaecide....it also is great at staining pools and causing hair to turn green. Unfortunately, the concentration at which copper ions kills algae is very close to the solubility limit of copper in neutral pH water (pH in the 7 range) and so you will eventually wind up staining your pool with copper scale. Copper scale, unlike iron scale, is actually a lot harder to remove and so any actual benefits from copper are not worth the costs.
    Unfortunately, without knowing how much copper is in your water, there's no way to know how much you need to drain. Take a water sample to your local pool store and tell them you need to test for copper metal. They can typically give you a ballpark number.
    Matt
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    You don't really need to get rid of your SWG, just disconnect the plug that goes to the copper electrode, I had one before
    8,400 gal 3K GPH pump, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    May 2015
    21
    Quote Originally Posted by Piolin View Post
    If I unplug the copper electrode it won't produce chlorine, am I able to use the chlorine pucks 'till I purchase a new SWG?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    You'd be better off manually adding bleach
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    There should be three wires running to the SWG, one to the flow switch, one to the salt cell, large flat one, and one to the copper cell. My earlier Intex SWG had one so I just removed the wire from the copper cell. Search utube and there is even a video of people removing the copper cell.
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    May 2015
    21
    Quote Originally Posted by LFrankow View Post
    This may be a stupid question, but if I'm unplugging the copper cell so that it doesn't produce chlorine that in turn is putting copper into my pool, would just turning off the SWG unit be the same, and I can keep it all hooked up to the pump and pool 'till I get and new one?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by Bon View Post
    It will produce FC just fine I used it for almost a year, there it tons of post about this issue in TFP from a few years ago
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    The copper cell doesn't produce chlorine. The SWG does.
    May 2015
    21
    Quote Originally Posted by Mr Bruce View Post
    Thanks for your responce "Mr Bruce" Excuse my ignorance, but what is the purpose of the copper cell?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    See JoyfulNoise's post #5
    May 2015
    21
    I unplugged the copper cell, what do I do with the exposed prongs, do I need to cover them up to prevent possible shorting the system from rain/water?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I didn't do it, and everything was fine
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Just remember you now are not adding more copper, but you need to get rid of the one you have in the pool, follow instructions in post 5
    May 2015
    21
    Thank you so much "Piolin" and everyone else for all your help, very much appreciated!
