Thread: Tricholor puck life span
    Apr 2013
    Phoenix,AZ
    39
    Wondering if the Tricholor pucks degrade in the same way liquid chlorine does.....I ask because we are going to be out of town for 5 days and I plan on using 2 or 3 Tricholor pucks in a floater and the pucks I am using have been stored in my garage in Phoenix for 2 years when I went on the TFP method......
    Phoenix, AZ USA 12k gal, IG pebble, Pentair TR-100 sand filter, Jandy/Zodiac ePump series-variable speed, builit 1991 (re-plastered with pebble 2013-new pump 2011), Taylor 2006 test kit with (FAS-DPD) chlorine test w/speedstir, Spa attached
    JoyfulNoise's Avatar
    May 2015
    13,171
    Re: Tricholor puck life span
    The answer is no, stabilized chlorine does not degrade like hypochlorite solutions do. As long as the pucks remained dry, they can last for years. The decrease in available chlorine would be undetectable.
    Matt
    Apr 2013
    Phoenix,AZ
    39
    Thanks for the info......
