Results 1 to 10 of 10
Thread: Jandy 1400 tri port sensor
    May 2014
    Pflugerville, TX
    148
    My sensor is reading 25,000 ppm of salt. I turned the system off and took the sensor out and one of the metal contacts looks burned up.
    Will the new sensor with just the 2 contacts and the little control box work? My firmware is 11230A05 and the manual doesn't mention this explicitly.
    This manual: http://www.jandy.com/~/media/zodiac/global/downloads/h/h0425400.pdf
    Model R0452500 ?
    May 2014
    Pflugerville, TX
    148
    Re: Jandy 1400 tri port sensor
    The new sensor will work with your system. You have to put the little control box on program “B”.
    Support the site
    May 2014
    Pflugerville, TX
    148
    That's what I gathered from the manual but wanted confirmation. Thank you.
    Make sure that you’re getting the latest model. There are still lots of the older style sensors out there. They have the same part number, so ask if it’s the newest model.
    Support the site
    May 2014
    Pflugerville, TX
    148
    How can you tell?
    You have to ask. It has the controller inline.
    Support the site
    May 2014
    Pflugerville, TX
    148
    Yes I did order one with the inline controller. I assumed you meant there were several different versions of that as well.
    May 2014
    Pflugerville, TX
    148
    New pig snout sensor with the little PDA is in place and working. Most excellent.
    Support the site
