Thread: Spring 2017 build
    Jul 2016
    Genoa
    3
    Spring 2017 build
    I'm starting to plan a spring 2017 build in Northwest, Ohio. First let me say I am can't believe the price differences between the sunbelt and the rustbelt. Pools just seem so much cheaper in the south and west. I am leaning towards being the general contractor and subcontracting the work out. It seems like concrete pools are rare in the north is this because of the winters and cracking issues? I am leaning towards a steel wall vinyl lined pool. Any recommendations on where to purchase a kit from? Any suggestions on subcontractors in northwest ohio?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,797
    Re: Spring 2017 build
    Welcome to TFP.
    I honestly think the reason that concrete pools are less common up north is because they require a specialized set of contractors (gunite mostly but rebar too) that are not generally present. But that's neither here nor there. Doing an OB on a vinyl pool doesn't have the same bang for your buck that a concrete pool does. But hopefully someone will be able to give you some helpful advice pertinent to your geography, pool type and OB interest.
    You are certainly researching at an appropriate time in advance.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
