Thread: Need help with my TF 100 kit
    Jun 2016
    San Diego, CA
    31
    Hello I just got my TS 100 kit and I'm confused about how to test the acid demand.
    I can't seem to find it on the help section.
    My pH is 8.2
    My old test kit had a reagent to see how much acid was needed.
    How do I do this with the TF00 kit?
    Thank you
    Salt water 28,000 Gal Pool with 1,200 Gal Spa
    Satin Matrix Pebble surface
    Pentair Intellichlor Salt Chlorinating system, Pentair Intellifo Variable Speed Pump
    Pentair 400,000 BTU heater, Dolphin DX5S Robotic pool cleaner
    750 sq foot Solar Pool Heating, Rock Grotto with waterfall
    30,432
    Re: Need help with my TF 100 kit
    The TF-100 does not have an acid or base demand test.
    PoolMath on this site will calculate the dosage for you.
    Simply put in your pool gallons in the upper left and then put in your current pH and then the pH you want and it will calculate it for you.
    Jun 2016
    San Diego, CA
    31
    Thank you for the quick reply
