Results 1 to 7 of 7
Thread: Where Did It GO??
    Where Did It GO??
    Checked CYA approx. one month ago. It was as 30ppm as I wanted. Yesterday I checked again and got under 20ppm. I could fill tube to the top and still clearly see the black dot in the bottom. I'm using tfp test kit. I rechecked 4 times and still got the same results. I have added muratic acid last few weeks as PH has been going up. New vinyl liner installed at beginning of season,I do not know if this would affect PH or not. I'm trying to figure out where the CYA has gone???
    I have not had to back wash as our normal rains have not happened this summer. I'm in the process of dissolving granular CYA with the sock/skimmer method to get back to 30-40- ppm. Any ideas on the CYA disappearance??
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Where Did It GO??
    It is a very subjective test to read with a +/- of 10ppm accuracy, so differences in lighting the day of the first test vs the second test could account for the difference. Had you noticed changes in how chlorine was being consumed lately?
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Lewisberry, PA
    93
    As stated above, CYA testing is a bit tricky and subjective to conditions. Also, it may take 48 hours after you add stabilizer to get an accurate reading.
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    yes---- more chlorine use lately--
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    I tend to lose some CYA but know mine is from rain overfill/drain. That is why I test it at least once a month just to be on the safe side.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    CYA does also slowly break down in the pool, although the rate is so low it is not a practical way to lower CYA when it is extremely high, this happens faster the warmer the water is, so loss of 10 ppm over the summer when the water is hot is understandable. Monthly CYA replenishment is important for hot tubs tat are constantly maintained at 103+ degrees F.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    CYA tends to drop 2-3 ppm per month, up to 5 ppm when it is hotter.
