max2k
0
Good morning to everyone,
I believe the black stains are copper stains, not black algae. Two words: pristine blue. Chief of Staff starting using that product line unbeknownst to me and the day after she added "lithium something" the stains showed up.
Here are my numbers from this morning:
FC- 4.8
CC- 0.6
PH-<7.0 (tested several times)
CNA- 90-100
TA- 110
CH-350 (tested several times)
I tested my FC last night at sundown, it was 9. This mornings test was after sunrise but before and direct sunlight hit the pool due to tree shade. Something is eating my chlorine.
Standing by further instruction.
Thanks
If I understand you correctly CNA is Cyanuric Acid. If so it goes by abbreviation CYA around here, try to switch to reduce confusion.
In general, you need to go through SLAM where you'd bring FC concentration to higher than normal level and keep it there by often additions until whatever is in your water stops consuming FC. Unfortunately, your water is not in the best shape to start the SLAM at the moment, it would be the best to perform partial drain first.
It would achieve 2 objectives:
- partially get rid of Pristine Blue in your water
- bring down CYA to more sensible level so you won't need very high FC during SLAM.
Before you drain though you need to add sequestration agent to pool to lift copper back to water so when you'll be draining you'll be getting rid of it efficiently. Jack's Magic is recommended brand around here but my expertise in metal staining is very limited; hopefully someone else will comment on that. So general plan is:
1. Bring your FC to 10-12 ppm using liquid bleach or you risk pool turning green very soon. This is just for you to be able to 'hang in there', not really to fix anything.
2. Add copper sequestration agent
3. Drain 50-60% of water in 2 - 3 runs. Please find out how high is your natural water table. In rare circumstances when water table is high and significant portion of pool water is drained the entire pool can float out of the ground leading to extremely costly repairs. At the end of this step you need CYA to be in 30-40 ppm range.
4. Perform SLAM.
Please do not add anything to the water unless advised from this forum or we won't be able to figure out what is going on at the end. Please use only liquid bleach as source of chlorine. No 'shocks', tablets, pucks or other forms of solid chlorine as it will bring additional CYA into the mix.
