Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Does chlorine kill established black algae?
    Jul 2016
    tulsa,oklahoma
    33
    I was reading the Taylor 2004b (instruction book that comes with K-2006 test kit) and it said that chlorine will not eliminate or kill black algae. The manger/owner(?) of the pool supply store in which I was reading this, echoed those same comments. So of course I bought some Black Algae Algaecide.
    Additionally, he said to be sure to vacuum to waste any area where you have brushed.
    Comments?
    32,000 gallon IG plaster (redone in 2003)
    Filter: Triton II sand
    Pump: Pentair Challenger 1 HP
    Test Kit: Taylor 2006
    30,431
    Re: Does chlorine kill established black algae?
    Chlorine kills algae. It will kill black algae but it is often difficult to get the chlorine to the black algae as it is most often embedded in the masonry surface.
    Daily brushing with a stainless steel brush and constant exposure to chlorine will absolutely kill black algae.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    All algae can be killed by chlorine. Black algae is more difficult to kill and requires tenacity on your part to get rid of it. You must brush it daily and keep the chlorine elevated. After brushing the pool scrub any spots you can reach with a chlorine tablet, using rubber gloves to protect your hands. Check the label on the algacide, it probably contains copper, which in high enough levels will stain your pool.
    Love TFP? Become a
    TFP Supporter!
    Don't use the algaecide.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Here's a little more info from Pool School, Pool School - Black Algae
    Jul 2016
    tulsa,oklahoma
    33
    Quote Originally Posted by zea3 View Post
    I have already added the Black Algae Killer early this morning per the pool supply store recommendations. It does contain copper. (.27 lbs per gallon) and I added one qt, so about .06 lb.
    This is really frustrating, and humbling. I got into this mess because of bad/ misunderstood guidance from a different store. ��
    Can you describe the brushing process? I bought a 5" stainless brush to use. Do I bear down as hard as I can and how many strokes is considered adequate?
    Thanks
    Jul 2009
    Houston, Texas
    9,412
    You want to use firm pressure so you open up the "skin" of the algae so the chlorine can do its job. Give it a few strokes with the brush and it if looks like it took some of it off scrub it good with a chlorine tablet. You probably won't get all of the algae the first time and you don't want to scrape so hard you take all the plaster off. The pool school article in the post by pooldv has our recommendations for black algae removal.
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    tulsa,oklahoma
    33
    I have read read the Black Algae removal article several times, however the example pictures won't display either on my iPad or my desktop PC.
    When I brush I see a cloud surround the brush. Is that normal?
    Here are my pool numbers just obtained with my new K-2006
    CNA-52
    FC- 11.5
    CC-2
    PH-7.1
    30,431
    It sounds like you have more pressing problems than black algae. Your description and your test results indicate a need to SLAM your pool.
    You are missing CH and TA test results but you still need to SLAM, I think.
    How does your water look?
    Jul 2016
    tulsa,oklahoma
    33
    TA-140
    CH-450
    Water looks pretty good. Maybe slightly cloudy.
    Additionally, I tried to scrape some of the black alage with my fingernail to sample on a rub on white paper, but could not get any under my finger nail. But I have brushed the areas several times already.
    I will attempt to add a picture of my problem areas.
    Jul 2016
    tulsa,oklahoma
    33
    image.jpgN
    This is the only decent shot I could get. This is on the steps in shallow end. As you can tell, these aren't dime or quarter size patches. They seem to be large areas two to three feet in length and look like dark sediment, much like undissolved Shock lying on bottom.
    DFW, TX
    24,509
    I don't have any issues seeing the pics on my android Tab. Maybe these links to the pics will help.
    Trouble Free Pool
    Trouble Free Pool
    Trouble Free Pool
    Jul 2016
    tulsa,oklahoma
    33
    Quote Originally Posted by pooldv View Post
    Trouble Free Pool
    Trouble Free Pool
    Trouble Free Pool
    I cant open these links either. Not on iPad or desktop. "Invalid attachment specified"
    I’m not so sure that it’s black algae. I suspect that it might be copper staining.
    Support the site
    Jul 2009
    Houston, Texas
    9,412
    I think you are dealing with an entirely different problem. Black algae literally looks like small black spots. What you have looks more like metal stains or calcium scale. Have you ever used copper or mineral based products? How long have you had these patches? Did you recently lower your pH?
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    tulsa,oklahoma
    33
    The problem (whatever it is) manifested itself about a week ago after our chlorine level got real low to non-existent. This occurred due to a misunderstanding between my wife (the primary pool caretaker) and a person at a local pool store coupled with a gigantic amount of organic material in the pool after a huge wind storm.
    We have never used copper based products to my knowledge, with the exception of me using a copper based Algaecide this morning at the direction of a different pool store person. I told him we had black algae because wife said we had black algae, and it does look black.
    I am open for suggestions, because in short, I have no idea what I'm doing. But the endless stream of half-wits and lazy dullards that I paid for over the years surely are not smarting than I am. I'll figure it out. just gonna be painful getting there.
    Thanks
    Did the black stains happen when someone broadcast calcium hypochlorite into the pool?
    Black algae is very slow growing. It does not appear over large areas very quickly.
    Can you describe the events leading to the black stains?
    Support the site
    Jul 2016
    tulsa,oklahoma
    33
    Quote Originally Posted by JamesW View Post
    I am not exactly sure as I was out of town, and my wife was at the controls when the black stains showed up. And now she is out of town (and not responding to my texts)
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by poolbrush View Post
    I think you need to check if you're passing FC overnight loss test. This is simple test- you measure your FC after sunset and before sunrise so the Sun doesn't get a chance to shine on your pool. If the difference is < 1 ppm you're good but judging by cloudiness of your water I suspect it won't be the case. Please don't add anything to the pool during the test and turn off SWG if you have one. The idea is to find out if anything is consuming your FC in the pool. Just for water clarity reference- TFP water doesn't diffuse light beam from pool light .
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
  20. Back To Top    #20
    Jul 2016
    tulsa,oklahoma
    33
    Good morning to everyone,
    I believe the black stains are copper stains, not black algae. Two words: pristine blue. Chief of Staff starting using that product line unbeknownst to me and the day after she added "lithium something" the stains showed up.
    Here are my numbers from this morning:
    FC- 4.8
    CC- 0.6
    PH-<7.0 (tested several times)
    CYA- 90-100
    TA- 110
    CH-350 (tested several times)
    I tested my FC last night at sundown, it was 9. This mornings test was after sunrise but before and direct sunlight hit the pool due to tree shade. Something is eating my chlorine.
    Standing by further instruction. In the meantime, I will dig out my sump pump, as I don't have a main drain and I think a water replacement is in my future.
    Thanks
