Thread: Looking for a replacement impeller
    Jul 2016
    Arizona City, AZ
    13
    I have a SplaPool 72744 pump that the impeller is damaged. Without knowing the proper name for what is broken, I will try to explain it to you. On the front of the impeller there is a collar. That collar has broken. The pieces had wedged themselves in the impeller. I removed those, so it is not causing blockage in the impeller, but I still need to replace the impeller. I attempted to purchase one from INYOPOOLS, and they sent the wrong one - it is too small. After emailing back and forth they informed me that they do not have the correct one, even though it is listed on their website. INYOPOOLS seems to be the only place that I can find replacement parts for this pump online. Do you have any other resources for ordering parts for these SPLAPOOL pumps?
    Thanks in advance
    Tim
    Jul 2016
    Arizona City, AZ
    13
    Re: Looking for a replacement impeller
    After a further online search and process of elimination, I think I have found it. It turns out that this SplaPool Pump is also sold under the Valterra Brand, the Blue Wave Brand, and the Reliant Brand. I believe that I have finally found the part that I need on poolpartsonline.com
    SO, if you have any of those branded pumps, perhaps that will help you.
