Thread: Noob question....can I backfill dirt against my pool walls/posts?
    Jun 2016
    Colton, SD
    4
    Just finishing up my doughboy palm shore installation today, and I have some sections that are about a foot or so below grade. Can I just simply backfill against the walls posts with dirt or sand? Or do I need to drop mulch in there to create a barrier?
    Thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Noon question....can I backfill dirt against my pool walls/posts?
    As far as I know, Doughboys are rated to be fully buried. Adding mulch that would hold water is the last thing I'd do below ground.
    I know the landscaper coming to put stone around mine are putting a protective coating anywhere that is getting backfilled
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Put a couple of inches of pebbles or a french drain at the bottom, then cover with dirt. You want the soil to be able to drain well.
    Love TFP? Become a
    TFP Supporter!
