Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: New to Pool maintenance still trying to Clear up Cloudy water...
    EssieMae's Avatar
    Jul 2016
    Concord, North Carolina
    16
    Question New to Pool maintenance still trying to Clear up Cloudy water...
    Hi, I would really like some pointers and advice to know if I am or am not doing everything as I should. I am going to try to explain some of what I have been doing and I hope I make sense. If not please let me know so I can. Sorry if I ramble.. sooo many questions..
    I know it is late in the season but I am determined to get it crystal clear for my young'ns to get to swim in at least a few times this year. Also maybe I can have better control of it for next year this way. But I guess what I want to know is if I am doing the right things and if so, I know it can take awhile but
    1)HOW LONG IS IT GOING TO TAKE MY SAND FILTER TO CLEAR MY POOL??? (It's terrible I know but I have been so excited and getting very impatient --I have always wanted an IG pool and now I would like to get to enjoy it with our children! )
    Here is what I have done (best I can remember from my notes).
    We have scooped the bottom with a leaf rake and gotten as much debris from the bottom as we could find.
    The pool chemistry has been steadily tested and maintained at normal/ideal levels since 7/22 (that includes Chlorine, PH, Alkalinity)
    I have been using the bbb method (minus the bleach at first- the exception of also using Trichlor tablets and granules (XtraBlue 3"Long-lasting chlorinating tablets and XtraBlue All-in-one chlorinating granules, to be exact). We were doing small shocks 1-2 pds every other day or so, then I realized I probably wasn't reaching the breaking point so..
    7/24 I super chlorinated (slammed as I guess you would say) with bleach to what the pool calculator said would up it to 30ppm (my test kit doesn't go over 5ppm; btw I know I need a better kit, I have heard a lot about the K-2006 so 2)WHICH TEST KIT DO YA'LL RECOMMEND??)
    The pool color has drastically improved since superchlorination too.
    3)HOW LONG DO I NEED TO MAINTAIN SLAM LEVELS? (the entire time until the water is clear or do I just need to maintain "ideal" chlorine levels now???)
    We have been filtering 24 hrs/d since 7/22...but 7/25 started our best filtering day from there out. I have always backwashed as necessary (when psi reach 7-10 over normal). 7/25 I also started adding Clarifier (clorox pool & spa Super water Clarifier). I have added 4.5 ozs 3 different times, as the bottle says you may reapply after 36 hrs if water is still not clear. It has drastically improved the filtering because now I see chocolate milk colored water while backwashing and it was never that dark before. 4)DOES CLARIFIER DISSIPATE OVER TIME? SHOULD I BE ADDING MORE OR KEEP ADDING MORE EVERY 36 HRS OR AM I ADDING IT TOO OFTEN???? I know too much can continue cloudy water but I really don't think it is the case with this one but idk, I jus know it is helping improve the sand filtering.
    I have been using my 5 way test kit every day, but on 7/27 I did buy a sample strip kit test to get an idea of the cya levels (yes I know they can be not as accurate). All other results matched what I have been getting with my normal testing. The strip results were
    Total Hardness: 250
    Total Chlorine: 10
    Free Chlorine: 10
    PH: 6.8 (I also added borax and got this back ideal)
    Total Alkalinity: 120
    Stabilizer: 50
    Now on to my next question/concern. I know I need to invest in a better kit, but as of right now I would like to know if I am understanding chlorine results right on my current kit. I can read FC (up to 5ppm, then I have to guess from there) but I get confused with what it calls the Combined Chlorine reading. I guess I am not getting a TC reading. It says the "chlorine residual can exist as free (active) chlorine and/or combined (less effective) chlorine". To test, it says Within 2-3 seconds you can read the FC levels,and Wait 1-2 minutes to determine the CC "chlorine residual" as it calls it. 5)IS THERE A WAY TO GET TOTAL CHLORINE READINGS FROM THIS?) Also, almost EVERYTIME I test the FC and CC readings are almost identical...IS THAT WHAT I WANT TO SEE OR IS THAT A PROBLEM????
    So anyway...
    On 7/28 I tested with 5 way
    FC-4 ish
    CC-4 ish
    PH-7.4
    ALK-100
    My husband threw in some granules that night. (like I said, we don't know if the chlorine concentration should be higher while in the clearing process)
    Tested again 7/29
    FC-orangy-red (way above 5ppm)
    CC-same as FC
    PH-7.4
    ALK-100
    I do attempt to brush the pool every other day or so (its a little hard to tell how good when I can't see the bottom).
    Am I doing everything right/ok?? It seems to be slowly getting better, so is it just a waiting game or is there something I can do to speed up the cloudy water clearing process??? (Wish there was a magical process to instantly clear the water)
    OMG I just previewed this and saw how much I wrote!! I know this is probably a lot of un-needed, jumbled information, but if anyone would dare jump into it and give me some advice I would Appreciate it SO MUCH.
    Thanks Jessica
    20,564 gallon, 18x36 double roman end, IG, vinyl liner, Pentair Tagelus TA-60/60D sand filter, 1hp Pentair WhisperFlo Pump model WF-24, well water, Taylor TF-100 test kit
    Built 2005. Pool untouched 5+yrs.(since before buying home) amazingly all parts including liner still working and in fantastic shape :D
    New to Pool World, am learning, been reading up all I can! :D
    Jan 2012
    'burbs of Augusta, Georgia
    7,259
    Re: New to Pool maintenance still trying to Clear up Cloudy water...
    Quote Originally Posted by EssieMae View Post
    .. sooo many questions..I'm going to try to answer as many as I can by inserting into your post my input,'k?
    I know it is late in the season but I am determined to get it crystal clear for my young'ns to get to swim in at least a few times this year. Also maybe I can have better control of it for next year this way. Absolutely it should simplify things for next year. Will you be "closing" your pool over the winter or keeping it "open"?
    1)HOW LONG IS IT GOING TO TAKE MY SAND FILTER TO CLEAR MY POOL??? That depends on if the filter is ONLY filtering out dead algae, or is it having to deal with a constant level of reproducing algae....? During a SLAM the more often you test and re-dose to being the FC up to your SLAM level the faster it goes. Down the road towards the end of the SLAM we often suggest the addition of a little bit of DE to the filter to help improve its filtering of small stuff. But not until the end, 'k?
    We have scooped the bottom with a leaf rake and gotten as much debris from the bottom as we could find. Good! The more stuff in there, the longer it takes to clear.
    The pool chemistry has been steadily tested and maintained at normal/ideal levels since 7/22 (that includes Chlorine, PH, Alkalinity)Whose "ideal" levels? Here is our recommend levels: Pool School - Recommended Levels But remember those are for when the pool is in ideal shape.... if you have algae and other problems those have to be fixed first before reverting to the "recommended levels".
    I have been using the bbb method (minus the bleach at first- the exception of also using Trichlor tablets and granules (XtraBlue 3"Long-lasting chlorinating tablets and XtraBlue All-in-one chlorinating granules, to be exact). Aaack! No more "Blue" products!! They contain copper, which lead to staining and green hair.
    We were doing small shocks 1-2 pds every other day or so, then I realized I probably wasn't reaching the breaking point so..We agree.. you have to do a prolonged SLAM process (Shock Level and Maintain) until the water is clear and passes 3 criteria: Water is CLEAR, CCs are 0.5ppm or less and OCLT shows 1ppm or less loss.
    WHICH TEST KIT DO YA'LL RECOMMEND??) TF-100 is a better choice as it has more reagents for the tests you'll be doing the most. Get the Speed Stir device too... simplify your life Both available at TFTestkits.net and they ship from NC so you should get it quickly.
    The pool color has drastically improved since superchlorination too. Once you get the test kit you'll be able to do a proper SLAM.
    3)HOW LONG DO I NEED TO MAINTAIN SLAM LEVELS? (the entire time until the water is clear or do I just need to maintain "ideal" chlorine levels now???) Without the proper test kit which contains the FAS-DPD chlorine tester (measures up to 50ppm) you haven't really been sure of your levels so you might not have ever reached your SLAM level? Also your level depends on your CYA level. Do you know that?? Pool School - Chlorine / CYA Chart
    We have been filtering 24 hrs/d since 7/22...Yup, gotta do that during a SLAM. And backwashing when the filter pressure increases by 20-25%.
    7/25 I also started adding Clarifier (clorox pool & spa Super water Clarifier) Aaack! (again, sorry) We rarely to never suggest this product. It can sometimes cause more problems than you had before by gumming up your filter. ALL you need at this point is bleach, bleach and more bleach.
    I have been using my 5 way test kit every day, but on 7/27 I did buy a sample strip kit test to get an idea of the cya levels (yes I know they can be not as accurate). All other results matched what I have been getting with my normal testing. You NEED the FAS-DPD test, in the TF-100. 'nuff said. The strip results were
    Total Hardness: 250
    Total Chlorine: 10 That's the highest that tester goes....and it isn't providing you with a Combined Chloramines number
    Free Chlorine: 10
    PH: 6.8 (I also added borax and got this back ideal) Do you mean you raised it to 7.2 we suggest for a SLAM?
    Stabilizer: 50
    Now on to my next question/concern. I know I need to invest in a better kit, but as of right now I would like to know if I am understanding chlorine results right on my current kit. I can read FC (up to 5ppm, then I have to guess from there) but I get confused with what it calls the Combined Chlorine reading.Combined Chloramines is a fancy way of saying "contaminating cooties". I guess I am not getting a TC reading. It says the "chlorine residual can exist as free (active) chlorine and/or combined (less effective) chlorine". To test, it says Within 2-3 seconds you can read the FC levels,and Wait 1-2 minutes to determine the CC "chlorine residual" as it calls it. 5)IS THERE A WAY TO GET TOTAL CHLORINE READINGS FROM THIS?) Also, almost EVERYTIME I test the FC and CC readings are almost identical...IS THAT WHAT I WANT TO SEE OR IS THAT A PROBLEM???? THIS is why you NEED that TF-100 with the FAS-DPD test. It performs both individually and ACCURATELY.
    My husband threw in some granules that night. (like I said, we don't know if the chlorine concentration should be higher while in the clearing process) No more granular or puck products, please. They add either more CYA which you don't want now as it raises your SLAM level higher or calcium which vinyl pools don't need ever unless they have a heater.
    I do attempt to brush the pool every other day or so (its a little hard to tell how good when I can't see the bottom). Brushing is good! It disrupts any biofilm that algae makes to protect itself from the chlorine. It also gets "schtuff" into circulation so that the filter can do its job on it.
    Am I doing everything right/ok?? It seems to be slowly getting better, so is it just a waiting game or is there something I can do to speed up the cloudy water clearing process??? (Wish there was a magical process to instantly clear the water) You're sort of spinning your wheels at this point. Go to TFTestkits.net and order that test kit (you can thank me later, lol) and go stock up on liquid chlorine (aka 8.25% or higher bleach or "liquid chlorine" from pool section) Check prices and date codes to get cheapest and freshest stock.
    Thanks Jessica
    Jessica, we can definitely help you but you have to do the SLAM properly- have you read this yet? SLAM
    We also love pictures if you can add a few? Its fun to watch the water clear up day by day.
    Yippee
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    +1 to ordering a TF-100 from TFTestkits.net and then following this process exactly, SLAM
    Jul 2015
    Knoxville
    72
    I promise u when u get the test kit and follow the advise of these wonderful people here u won't be disappointed, I am a new to me first time pool owner this is my second season and I am still learning stuff everyt time I come on here and I admit that I don't know everything but thanks to the guys and gals here when I have a problem I come here for the advise as its much better and less expensive than the uneducated opinions of the pool stores who only care about spending far too much of your money on stuff you don't need and will prolong the the sparkling oasis we all desire, I wish u luck but hang in there U CAN DO THIS....lol
    26k (roughly, irregular shape) 10' at deepest diving board and waterslide, IG gunite, 1hp Hayward super pump, 3/4 hp pusher for Polaris280, Hayward s244t sand filter, auto tablet chlorinator, clueless owner.... Knoxville tn, #tf-100 owner#
    EssieMae's Avatar
    Jul 2016
    16
    Thanks it's look'n a little clearer everyday, slooooowly.
    Looks like a lot of good stuff on this site. Thanks for the pep talk ignoranceisbliss, fingers crossed it won't be much longer
    Thanks pooldv and yippeeskippy, I ordered the tf-100 now awaiting its arrival so I can hit the slam hard an be on spot with the chlorine levels
    Aug 2014
    Northern IL
    4,615
    That's great, but... You can't really do it without the FAS-DPD kit. Please order one. You won't regret it. Promise.
    EssieMae's Avatar
    Jul 2016
    16
    Quote Originally Posted by MarianParoo View Post
    thanks, I have ordered the TF-100 FAS-DPD kit it is in the mail!
    Aug 2014
    Northern IL
    4,615
    Good for you!!!
    EssieMae's Avatar
    Jul 2016
    16
    Talking Re: New to Pool maintenance still trying to Clear up Cloudy water...
    Quote Originally Posted by YippeeSkippy View Post
    Yippee
    Thanks! I have read about the SLAM
    I ordered the TF-100 kit, here's answers to your other q's:
    I know it is late in the season but I am determined to get it crystal clear for my young'ns to get to swim in at least a few times this year. Also maybe I can have better control of it for next year this way. Absolutely it should simplify things for next year. Will you be "closing" your pool over the winter or keeping it "open"? I plan on "closing". It's outside, I figure that's what most people do?
    The pool chemistry has been steadily tested and maintained at normal/ideal levels since 7/22 (that includes Chlorine, PH, Alkalinity)Whose "ideal" levels? "Ideal" level marks were indicated on my current test kit vials but now I know those are for "normal" pool conditions.
    I have been using the bbb method (minus the bleach at first- the exception of also using Trichlor tablets and granules (XtraBlue 3"Long-lasting chlorinating tablets and XtraBlue All-in-one chlorinating granules, to be exact). Aaack! No more "Blue" products!! They contain copper, which lead to staining and green hair Just curiosity and for future knowledge, How do you know a product for sure contains copper??
    We have been filtering 24 hrs/d since 7/22...Yup, gotta do that during a SLAM. And backwashing when the filter pressure increases by 20-25%. Forgive me, but I been pondering what you mean by 20-25% increase. I've always read about 8-10psi over normal running pressure and that is what I do, is that what you mean?
    Clarifier (clorox pool & spa Super water Clarifier) Aaack! (again, sorry) We rarely to never suggest this product. It can sometimes cause more problems than you had before by gumming up your filter. ALL you need at this point is bleach, bleach and more bleach. Got it!
    PH: 6.8 (I also added borax and got this back ideal) Do you mean you raised it to 7.2 we suggest for a SLAM? Correct
    Will post pics soon
    EssieMae's Avatar
    Jul 2016
    16
    Smile Re: New to Pool maintenance still trying to Clear up Cloudy water...
    This was taken Fri. 7/29
    I will try to post a new picture tomorrow and see if there is noticeable gain!
    Jan 2012
    7,259
    I plan on "closing". It's outside, I figure that's what most people do? In your neck of the woods, its a toss up. Some do, some don't.
    "Ideal" level marks were indicated on my current test kit vials but now I know those are for "normal" pool conditions. Sometimes the TFP ideal levels aren't the same as pool stores for example. So we like hard core numbers to work with or base our care on.
    Just curiosity and for future knowledge, How do you know a product for sure contains copper?? Copper containing products are often listed as "Blue" per an old chemistry name for copper- "Blue Vitriol". And by reading the MSDS.
    Since everyone's baseline number is different, monitoring it by 20-25% is a better way to describe the point in which it needs backwashing.
    Will post pics soon
    The pic is cute.. love the ducks
    EssieMae's Avatar
    Jul 2016
    16
    20160803_194942.jpg this was taken 8/3 a cloudy day, not sure if ya can tell much difference by the pic.
    EssieMae's Avatar
    Jul 2016
    16
    Question Re: New to Pool maintenance still trying to Clear up Cloudy water...
    ok my tf100 kit came the other day, been doing the tests and results have seemed to be good
    I know my cya is too high and I am going to do some vacuuming to waste tomorrow and refill some to hopefully correct that problem.
    Here are the results I have gotten:
    8/4
    FC- 24.5
    CC- 0
    TC- 24.5
    PH- 6.8 (low I know)
    CH- 75
    TA- 70 (also getting a little low)
    CYA- 100 (eek)
    8/5
    FC- 22
    CC- 0
    TC- 22
    PH- 6.9 (need to buy more )
    CH- 75
    TA- 80
    CYA-100
    Aside from needing to increase my PH, and the CYA being sky high.....
    On the evening of 8/5 I did an OCLT= 25
    Morning of 8/6 OCLT= 24
    So I feel like I am basically good on all results and have 0 CC, only 1.0ppm loss of FC from OCLT, other than the water not being completely clear yet I guess I am not in need of another severe SLAM??
    I am figuring the still slightly cloudy water is from high CYA levels????
    I bought some DE to add to my sand filter, am I safe to add to it now per the pool school guidelines?
    Thanks in advance!
    Jessica
    Aug 2014
    Northern IL
    4,615
    I doubt the cloudiness is from the CYA. I am more worried about that low pH. We normlly don't recommend testing pH during a slam as it tends to read HIGH, not low.
    Yes, you can add DE.
    Did you ever do a dilution test on the CYA?
    EssieMae's Avatar
    Jul 2016
    16
    I doubt the cloudiness is from the CYA. I am more worried about that low pH. We normlly don't recommend testing pH during a slam as it tends to read HIGH, not low. If your worried that it's real low, what target level do you suggest I try to get the PH up to??
    Yes, you can add DE. Yay
    Did you ever do a dilution test on the CYA? Yes, I double checked on the second day testing by doing that, it hit right near 50 so I doubled it to confirm the 100ish level
    So do you think I still need to maintain high Chlorine levels or should I let them drift down and if so, to what levels??
    Also thanks for the quick response!
    DFW, TX
    24,450
    The problem with 6.8 on the PH test is that it is the bottom of the test range and it could be much lower. PH below 7.2 is corrosive and can damage pool equipment. I would be inclined to let FC drop to 10 ppm and recheck ph. When is the last time it tested at7.2 or higher?
    Same problem with the cya test 100 is the top of the test range and it could be much higher. We've seen readings of 100 when it is really 200, 300, or even 400. The diluted test is here, Pool School - Extended Test Kit Directions
    Aug 2014
    Northern IL
    4,615
    I would shoot for 7.2 on the pH.
    If it were my pool, I would do another OCLT for peace of mind. Then you should know if the cloudiness is due to algae or filtering.
    Have you deep cleaned your filter? If you pass the OCLT, you may want to try it.
    Deep Cleaning a Sand Filter
    Dec 2014
    Santa Ana, CA
    523
    With CYA that high you will need to drain/refill at least 50% of your water.
    Is this an option?
    What water source will be used for refill- city/well/smth else?
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    EssieMae's Avatar
    Jul 2016
    16
    Quote Originally Posted by pooldv View Post
    The problem with 6.8 on the PH test is that it is the bottom of the test range and it could be much lower. PH below 7.2 is corrosive and can damage pool equipment. I would be inclined to let FC drop to 10 ppm and recheck ph. So don't up the PH at all until the FC drops to 10??? When is the last time it tested at7.2 or higher? 8/3 (wed.) So could ya'll also be suggesting low ph could be the blame for the still cloudy water then??
    I attempt the diluted test on 8/5 but I will try again
    Thanks!
  20. Back To Top    #20
    EssieMae's Avatar
    Jul 2016
    16
    If it were my pool, I would do another OCLT for peace of mind. Then you should know if the cloudiness is due to algae or filtering. Okay
    Have you deep cleaned your filter? We cleaned out the tank and replaced with all new pool filter sand at the beginning of our venture, say end of June, first of July. If you pass the OCLT, you may want to try it.
    Thanks again
    Quote Originally Posted by max2k View Post
    Is this an option? It's not an option I would really like to consider, lol
    ​We have well water..
