Thread: Intex ultra frame - one bracket is not vertical
    May 2016
    Seattle WA
    15
    Today was the first day that I actually swam in my new pool. The water looks awesome and it's finally not too frigid. And then I noticed it this evening.
    One of the U-brackets that holds up the frame is noticeably out of vertical, maybe an inch out of its 52" height. It's at one of the corners. All the rest are OK. The pool sits on a perfectly flat and level concrete pad.
    How critical is it that this bracket be addressed?
    Intex Ultra Frame 12x24, Intex 1500gph pump $ sand filter combo, Intex Ozone SWCG, Empty Feeling in Wallet
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Re: Intex ultra frame - one bracket is not vertical
    Share a picture so we know what you are dealing with.
