Thread: balance between TA and PH
    May 2014
    Plainsboro, nj
    28
    pool size - 28500
    CYA 25
    Chlorine 4
    TA-90 PH 7.8
    My PH is fluctuating between 7.5 to 7.8 . it did reach to 8 but i added dry acid and now its fine. but TA is low. its 90. not sure if I should add baking soda to bring it up. as that is again going to bring PH up. please suggest.
    Also CYA is 25. I do not add any other shock powders . Use only laundry bleach. do i have to bring the CYA up?
    Archana
    Hayward Pro Series Multi port filter
    18x36
    115 feet perimeter
    Vinyl liner
    TFTestkits
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: balance between TA and PH
    HI there
    How are you testing? Can you add that to your signature?
    Yes, you should probably bring CYA up to at least 30.
    If your PH is creeping up, you don't ...do not, want to raise your TA. You may actually find it needs to be lower. But just focus on the PH adjustments and your TA and PH should find a happy spot.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2014
    Plainsboro, nj
    28
    Thanks. I use TFtestkit. I have Basic 1000 for PH testing .
    18x36
    115 feet perimeter
    Vinyl liner
    TFTestkits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Recommended TA is 50-90
    Let it drop, adding acid to lower PH will also lower your TA.
