Results 1 to 7 of 7
Thread: hardness test
    Jul 2016
    slidell
    58
    hardness test
    ph 7.8
    Alk 120
    Stab 50
    FC 2
    CC 1
    I have traditionally gone to pool store for this test but was wondering if anyone knew the Taylor R # and procedure for testing hardness on my own?
    Last reading was on july 1 : 60 and Leslie's says "too Low"
    thanks
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
    May 2016
    Phoenix AZ
    128
    Re: hardness test
    What are you using to test your other numbers?
    You should definitely get your own test kit and not rely on pool store numbers. My personal recommendation is the Taylor TF100 with XL option and speedstir, but others might have a different recommendation.
    Your FC is too low for your CYA level. You should add some right away to get your FC up.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    Jul 2016
    slidell
    58
    Re: hardness test
    ph : using the Cl Br Ph comparator
    alk and Stab : Leslie's pool store
    Fc and CC : Taylor R - 003, R - 870 and R 0871
    when you say "add some right away to get FC up" you mean liquid Chlorine ?
    May 2016
    Phoenix AZ
    128
    Re: hardness test
    Yes. Use this http://www.troublefreepool.com/conte...art-slam-shock to get a good idea of what your target should be and
    this http://www.troublefreepool.com/calc.html to determine the amount you need for your pool.
    TF100 can be bought here: http://tftestkits.net/splash-page.html
    ETA: it looks like you have what you need to test for Ph and FC. I think you can just order the CH test alone from Taylor, but I would also recommend having your own tests for TA and CYA. It's up to you, though.
    Jul 2016
    slidell
    58
    Re: hardness test
    thanks I looked at calculator one last question which is the hardness formula "CH" ?
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: hardness test
    The Taylor K-1770 kit is a stand-alone CH kit and you can get it online at places like Amazon (Amazon.com : TAYLOR TECHNOLOGIES INC K-1770 TEST KIT CALCIUM HARDNESS : Swimming Pool Liquid Test Kits : Patio, Lawn Garden). It has the R-0010, R-0011L and R-0012 reagents and a graduated cylinder.
    But, honestly speaking, CH tests are performed fairly infrequently (typically once per month) and calcium hardness doesn't typically require a lot of adjustments, so it's kind of waste to purchase a single use test kit like that as the reagents will go bad before you ever use them up. You'd be better off spending your money on a good, full service test kit like the K-2006 or a TF-100 and do all of the tests yourself. Most pool stores are pretty bad at the tests that you rely on them for, especially the CYA test which is critical to good pool care.
    Good luck to you.
    Matt
    May 2016
    Phoenix AZ
    128
    Re: hardness test
    Yes. CH = calcium hardness
    I used to get my water tested at Leslie's. The results were all over the place. Especially for CH.
