Thread: question re: measuring FC level when fighting black algae
    Jul 2016
    tulsa,oklahoma
    33
    Hello,
    We had an outbreak of black algae due to lack of chlorine and have joined TFP for guidance.
    We need to raise our FC level to somewhere between the high and SLAM level according to the guidance.
    In pursuing this course of action, I realized we need a better test kit. However when researching the Taylor and LaMotte (sp) kits, it looks like they only measure FC up to about 5ppm. Am I reading that right? If so, how do I know when I have the proper amount of FC in my pool for fighting black algae?
    Thanks
    32,000 gallon IG plaster (redone in 2003)
    Filter: Triton II sand
    Pump: Pentair Challenger 1 HP
    Test Kit: Taylor 2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Test Kit Question
    Welcome to TFP!
    The best test kit value is the TF-100 from TFTestkits.net. Here's why, Pool School - Test Kits Compared
    Jul 2016
    tulsa,oklahoma
    33
    Greetings,
    The article on treating black algae says to keep FC between high end and SLAM level. My question regards accurately measuring the FC level at that high of a content/ratio. Does the TFtest T-100 have the ability to measure high FC? I thought I read that it only read up to about 5ppm. i.e., if your is FC is 6 or 30, the test color would look the same. its seems that an important component of this battle is an accurate reading of FC, so therefore I am looking for the best way to measure that during this endeavor.
    Mark
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: question re: measuring FC level when fighting black algae
    Welcome to TFP!
    Yes, one of the reasons both the TF-100 and Taylor K-006 are recommended is that they both have the FAS/DPD chlorine test which will accurately test up to 50 FC.
    Support the site
