Thread: Next step after SLAM ????
    Jun 2016
    Blairsville GA
    22
    The SLAM is over and these are my readings:
    FC 12 (and dropping)
    CC 0
    TA 90
    PH 7.3
    CYA 40
    Salt 2900
    I know I need to increase CYA to 70 and that the CYA will lower the PH, but what about the TA - do I wait a week after CYA is in range? Also, we have NOT backwashed since SLAM ended (yesterday) since we had added stabilizer to get to SLAM of 40 (added on 7/25)
    Thanks for all the help!
    GeoJaneo
    21100k, IG, Vinyl, Pentair 1hp Filter, Sand, Pentair Superflow Pump, 2008, Polaris Vacuum, SWG, TFT-100, well water
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Next step after SLAM ????
    I would put your CYA in and wait. Your SWG may start causing PH to rise in which case you may want to adjust TA down a bit.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    Blairsville GA
    22
    Thanks - so no to the backwash before adding stabilizer? Note - we had very little visible algae when SLAM began only on pool ladder!
    GeoJaneo
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    you can if it makes you feel better
    But generally the advice is to back was when your filter pressure is 25% above your "clean" operating pressure.
    Jun 2016
    Blairsville GA
    22
    Nah, I'd feel better if I could swim, but it's raining cats, dogs, and maybe a few bears right now! Much thanx again !!!!
    GeoJaneo
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Raining bears or drinking beers?
