Results 1 to 12 of 12
Thread: Suggestion for a Quality ABove Ground Pool
    Hi All.
    My 18 year old AG pool finally collapsed.
    It was a 27'x54" high pool made by Home & Roam (out of business now).
    Can anyone suggest a quality replacement pool that is 27'x54".
    I have a very nice deck that was next tot he pool and I want to be able to re-construct a new pool next to the existing deck.
    Thanks for your help.
    Regards
    Sep 2015
    Rome, NY
    363
    Re: Suggestion for a Quality ABove Ground Pool
    Radiant pool
    Hello from Rome NY
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Quote Originally Posted by doc8404 View Post
    Radiant pool
    Hello from Rome NY
    Hi doc8404
    Hi doc8404,
    That's a nice looking pool... and huge !
    I've heard some good things about the radiant pools. I'll have to look around for a local dealer in Baltimore.
    Regards.
    Sep 2015
    Rome, NY
    363
    Thanks. The problem is you can't buy anything like a roller for the cover
    I have a cover roller already for my 27', so I plan to stay with the 27', plus I want the deck to fit properly.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    We have a Radiant Metric oval installed AG. We love it.
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Quote Originally Posted by Chasmengr View Post
    The Radiants look to be good pools. They do come in the 27' Round... BUT, they are only 52" high, and I need 54" to match what I had before.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Radiant's a great pool, nice and solid, and the insulation really helps keep the temp up.
    It might be worth putting a ring of 2" pavers on your existing foundation to bring it up to match your deck.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Quote Originally Posted by RyanMcC View Post
    Thanks for the suggestion.
    It's something I'll consider for sure.
    Regards.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    And put rigid Styrofoam sheets on the pool bottom thick enough to accommodate the extra paver height.
    Good idea... Thanks !
