Thread: how does the Spa get chemicals
    May 2015
    Fullerton, CA
    635
    So I have a schedule to run the spa overfill for 1 hour per day, the pump is running ten per day, so how do the chemicals in the spa get mixed with the chemicals in the pool? During this spill over schedule? I am assuming that the water spilling into the pool gets filtered and goes back into both spa and pool mixing them right? I know dumb question.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: how does the Spa get chemicals
    Nope, not a dumb question. And your answer is correct! Nice job on a Friday.
    May 2015
    Fullerton, CA
    635
    Quote Originally Posted by pooldv View Post
    thank man you are a huge help!! Can't wait to jump in the pool for the first time tomorrow!!
