Thread: Pump very slow to prime, appears to be tripping GFCI circuit breaker
    Jun 2016
    Massachusetts
    10
    I have an Hayward 1hp SuperPump and it has been taking longer and longer to prime and "fire up" as the summer goes on. A couple months ago I would hear it click on, and then start pumping a few seconds later. If I turn it off and then back on it fires up quickly but now it takes 7-10 seconds to start pumping if it has been off for a few hours. Also, it often trips my GFCI circuit breaker before it has a chance to start pumping. Has anyone heard of this happening? The circuit trips even if it hasn't rained for days and everything appears perfectly dry. I am thinking I need a new pump. If so, does anyone have any recommendations? The current pump is 1 hp but I think I need 1.5hp for our 35-40k gallon pool. Possibly a variable speed depending on price and power savings.
    Appreciate any advice in advance.
    40x20 in ground gunite - ~35k gallons - Hayward C5030, 525 sqft cartridge filter - 1hp Hayward Super Pump - Dolphin Triton vacuum - 2 skimmers, 4 return jets
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump very slow to prime, appears to be tripping GFCI circuit breaker
    How old is the pump? Sounds like the bearings might be going out. Is the pump any louder than it used to be?
    Mark
    Jun 2016
    Massachusetts
    10
    Quote Originally Posted by mas985 View Post
    I am not sure how old the pump is, I just bought the home 6 months ago. I can't decipher the age from the label but I suspect it is at least several years old. I don't believe it is any louder than before but I've only been using it since we opened the pool in May. It just seems to take longer to start up.
    mas985's Avatar
    Pleasanton, CA
    11,737
    More than likely the bearings are going out. You can replace that motor with a two speed: STS1102RV1
    Mark
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I think the motor is from 2009. CE I think is the date code.
