Thread: Curious about raising PH
    Jun 2016
    Lakeland, FL
    30
    I'm using an aeration method to raise my PH. I used PoolMath to check quantities for some of my other numbers but I noticed under PH it says to add either soda ash or borate.
    Is this a short cut to raising your PH? I'm going to stick with aeration rather than add stuff to the pool, but I was just curious.
    Thanks!
    FL Resident
    IG 18,000 gal plaster
    Hayward Swim Clear Cartridge Filter
    Hayward Swimpure Extreme swcg
    A.O. 1HP motor
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Curious about raising PH
    Yep, here is more info on what raises PH and how to do it.
