Results 1 to 7 of 7
Thread: It keeps coming back! HELP!!
    Jul 2016
    Jackson, GA
    3
    Question It keeps coming back! HELP!!
    Hello lovely people of trouble free pool. I'm hoping by joining and posting my pool problems I can actually join the club of a truly trouble free pool. Here's my problem....
    We keep getting this dirt like stuff at the bottom of our pool. I have vacuumed to waste once before and we have shocked the pool and it seemed to have went away for a short maybe 2 weeks tops. Now it is back again. I don't know what I am doing wrong. I thought it was algae and the shocking would get rid of it but it came back. We have an above ground 24 inch round pool. 48 inch deep. Our chlorine levels are currently still coming down from shocking so is is a bit high. The water is a bit cloudy and im going to try and post a picture for reference. I have read that it could be dead algae but it keeps coming back. What can I do to fix it? Is it actual algae or dead algae?
    Here is the chemical readings
    FC-6
    CC-0
    TA-110
    PH-7.4
    CYA-75
    pool.jpepool 2.jpe
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Re: It keeps coming back! HELP!!
    Welcome to TFP!
    Sure, you can be in the Pool Snob club!
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
    Jul 2014
    Hope Mills, NC
    567
    First, if your CYA is indeed 75 (we'll call it 80 just because) the recommended minimum your chlorine should ever go is 7.5% of 80 = 6.0 FC. That is the bare minimum it should EVER be. Bet they never told you that at the pool store???
    FC vs CYA is something that the average pool store simply ignores with the end result being that they get to charge you money to "fix" the problem. Here, we don't make any money and don't try to cover up problems.
    Reading the 2 topics posted above will get you a better understanding of what is actually going on in your water and how easy it is to control. The basic method is that regular and accurate water testing will tell you EXACTLY what to add, without any guessing.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    30,431
    Actually, you have both. On the bottom of the pool floor is dead algae but it comes from the live algae in your pool that is making your water cloudy. Read what pooldv suggests and then come back and ask any questions. You will need to SLAM but read the above articles first.
    That 2nd pic looks like mustard algae, no? When you brush it does it poof away in a cloud?
    15,000 gallon AG
    20" Aquaview Sand Filter w/1.5HP pump
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Quote Originally Posted by Chat View Post
    Clearly looks like regular old algae to me. Mustard is actually rather rare........even though many of think that's what we have at one point or another.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Quote Originally Posted by AimeeH View Post
    Fair enough, I'm going through a MA issue myself so now I see it everywhere. Must be the mustard colored glasses.
    15,000 gallon AG
