Thread: Intelliflo VS Pump Not Making Pressure for Spa
    Jul 2016
    Boca Grande, FL
    29
    For some reason, our new Intelliflo VS 3 HP pump cannot make enough pressure to make the spa jets work effectively. With the pump running at max speed, there is next to no pressure coming from the jets. It's not even enough to disturb the surface of the water. Pool builder is struggling to figure it out. The inserts are in the jet nozzles and look to have roughly a 3/8" orifice.
    We we drained the spa down to inspect the jets and they look fine. Water just sort of dumps out of them and has no pressure.
    The spa is roughly 5'x8' and has 8 jets. I believe all piping is 2".
    At at our previous homes, we had smaller pumps and almost too much pressure. On a scale of 1 to 10, this one is less than 1. The pump is roughly 25' from the spa.
    Im wondering if the pump may be running backwards or something like that. Is that possible if the pump is not wired correctly? Reversed phases?
    Thanks!
    12k gal Concrete pool & spa, Blue Lagoon PebbleTec, Pentair Intelliflo VS 3 HP pump, Ultra Temp Heat Pump, IC20 SWG, Easy Touch System w/ IS4, Cartridge Filter, Intellibrite Pool and Spa Lights. Built July 2016
    Dec 2014
    Houston, Texas
    134
    Re: Intelliflo VS Pump Not Making Pressure for Spa
    Pull the inserts, very common on new builds for trash to get in the plumbing and clog the inserts. What is the psi on the filter in spa mode at max speed? I'd imagine it would be pushing 40psi if there was a blockage. On the other end, if the impeller has a clog you'd hardly be registering a psi reading on the filter.
    As far as the phase goes it's not impossible but certainly improbable. I know the XF comes in 3 phase, I'm pretty sure the VS is only 1 phase. Anyway the model number should be #011018.
    Does the pump work fine in pool mode (psi wise)?
    Jul 2016
    Boca Grande, FL
    29
    Thanks for the quick reply. I just went outside and my PB is out there with a shovel. He thinks he crossed the lines between the blower and the jets. I guess the water is entering the jets where the air should enter and the air is entering the jets where the water should enter.
    He's digging now so hopefully that fixes it. I don't understand why they don't take 3 seconds and just label stuff.
    Thanks again.
    Jul 2016
    Boca Grande, FL
    29
    Looks like that was the problem. Still not as much pressure as pools we've had in the past with smaller motors but it seems much better now.
    Thanks.
