Thread: Pool math calculator- FC weight vs trade?
    93specv's Avatar
    Jul 2016
    New Hampshire
    21
    Experience in forums, new to TFP. I'm a searcher when it comes to forums and generally only ask when searching results is little to nothing. So needless to say, I searched...
    ...I'm curious when using the pool math calculator why when calculating FC and inputting 6 or 8% does the next field say "weight?" Then when inputting 12% does it change to "trade?"
    What is weight and trade in reference to bleach/chlorine and is it a liquid measurement? I assume it IS a liquid measurement by the next fields provided in the calculator.
    TIA
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Re: Pool math calculator- FC weight vs trade?
    Welcome to TFP!
    Here you go Pool math chlorine question
    93specv's Avatar
    Jul 2016
    New Hampshire
    21
    Thank you very much. Curious what your search terms were? Or did you just happen to know where that thread was?
    DFW, TX
    24,504
    I think it was
    trade weight joyfulnoise
    I remembered it from recently and knew joyfulnoise answered it.
    93specv's Avatar
    Jul 2016
    New Hampshire
    21
    No doubt. maybe cause I'm on a phone. Thanks
