Results 1 to 15 of 15
Thread: Pump and filter location
    May 2009
    St.Thomas, Ontario, Canada
    4
    Hi all, my wife and I have recently decided we would like to purchase a AGP and I'm still in the information gathering stage, and was wondering about pump and filter location. Most pools I see have them located as far from the house a possible and was wondering if the was any particular reason for this (is it loud?). I was thinking of placing it under the deck off the back of my house, which is enclosed and approx. 64 inches off the ground, so it would be out of the way and still easy to access. My biggest concern would be noise as this will be our main seating area. Unfortunately I don't know anyone with a AGP to see how loud the pumps are. The pump sold with the pool we are considering is a 1.5 hp single speed.
    Thanks ,
    Brad
    Brad
    Kamaki's Avatar
    May 2009
    Honolulu, HI
    1
    Re: Pump and filter location
    I like the idea of keeping the pump and filter out of sight. Just make sure you have enough room to access your equipment to make your life easier.
    I use a variable speed pump on a fairly low setting unless I'm vacuuming the pool; it's quieter than a refrigerator. Sometimes you can't even tell it's on. No problem being near the house based on noise if you use a pump on a low power setting.
    3K gal, plaster, SWG, 24" sand filter, Pentair IntelliFlo VS 3050 4-Speed Pump (worth every penny)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I would honestly go with a 1.5-2 HP, 2 speed pump if you can swing it, the low speed is very quiet, mine is right next to my house and my deck. High speed is much louder. Low speed yields great savings on electrical bills.
    Access is important, we built our deck after the fact and now I have to walk all the way out and around to access the equipment and sometimes that just gets very tedious. So consider everything before hand. Will you have easy access for cleaning/repair, etc.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Quote Originally Posted by frustratedpoolmom
    And to amplify the above...if your filter is a cartridge filter, and the access to the cartridges is via taking the top half off the filter, you have to have that much clearance to take the top off! If it's a sand filter, give enough clearance to open the top to remove or replace sand as needed.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I'll second or third the comments on the 2 speed pumps. I have a two speed 1hp pump, and can't hardly tell it's running while on low. In fact, it's situated just outside of my den window, and I can open the window at night and it doesn't bother us at all.
    BTW, pool dealers are notorious for selling oversized pumps. What size pool are you looking at? I was intially sold a 2 hp single speed pump, which was waaay more than I needed.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    May 2009
    4
    We are planning on going with a 15x 24, 52" , the "kit" the dealer offers comes with a 1.5 hp Hayward. Do you run your pumps 24/7? I'm still learning and I appreciate the feedback!
    Brad
    Brad
    Apr 2008
    UhhhHiya
    26
    I recently re-plumbed to put the pump and filter in the garage. Next step: insulation and drywall for the garage. I don't think my JEEP will mind the noise that much.
    10,600 Gallon 12x32x4 Above Ground
    Hayward Veri-Flo sand filter
    Hayward 1hp pump
    Taylor k-2006
    11,969
    I run my pump on low 24/7. I only run it on high if I need to vacume, which is rare because I have a bottom drain. The low speed barely puts a dent in my elec bill.
    I second the garage. I put all my equipment in the garage and ran rigid pvc out to the pool. I love not seeing or hearing the equipment, plus it keeps the equipment out of the element (no sun fading and rain).
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    Jul 2008
    Solon, Iowa
    170
    I have a 1.5 HP single-speed pump under my deck and the noise is not objectionable, in my opinion. Standing over it you clearly know the pump is running, but the noise would not be intrusive if you stood over it and had a conversation. I'd say it is on par with a high-quality dishwasher. I run mine from 9-5 once the pool starts getting heavy use, but that is mostly because I have a salt water chlorine generator that I set at a low duty cycle in order to maintain 3-5 ppm chlorine without taxing the generator.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Guest
    Quote Originally Posted by Antares
    Whoa! Can the equipment be put in the garage?
    I am in a cold zone and was wondering about bringing the equipment in every year. This way I could drain and blow the lines and just keep the equipment in the garage, which is heated with a system to keep it above freezing temps during the winter.
    Dang, I may have to update my Head calculation for the pump to run the pipes the extra 15-20 feet to the garage.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I don't see why not. Only problem I could see is if a seal goes or a pipe cracks, then your garage is flooded; other than that, I don't see a problem with it.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Guest
    Sounds like I need to put a flood pan in place to direct the water safely out of the garage.
    I put my pump behind my pool as far away as I could for noise and so I don't have too see it. Just have too remember that the further you put it, the more digging you will do and more electric wire. Be sure to check all the codes to make sure you can put your pump where you want it.
    Lomart 21ft round 11,000 gal 52"
    Hayward EC40 Perflex DE filter
    1hp Hayward Powerflo Matrix with micro timer
    Pool Rover JR ABG pool Vacuum (The best)
    Back up pump and filter
    Spectra 3 sand filter/ Promega 1 horse pump with timer
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    My pool is far enough from the house to not matter, but the pump is not that loud so it would not be an issue either way. We run ours on a timer - 10:00am - 7:30pm - we have the SWG running during that time.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
