Results 1 to 10 of 10
Thread: white crystals forming on ladder, HELP!!!!
    Jul 2016
    Philipsburg Pennsylvania
    4
    fc 5
    cc.5
    ph 7.3
    ta 80
    cya 50
    Im new , just getting started. Used pucks for yrs. Now using TFP method, using bleach. Water clear since starting this method. Have had all kind of problems in the past, but this is the first time I have ever seen white crystals growing on my metal ladder. Took it out and scrubbed and sprayed with bleach. Returned the ladder and the next day it started to grow again. Does anyone have an idea what this is and what I can do? Or any advice in general.
    I am new and all this stuff is stressing me out.
    Thanks everyone in advance.
    20k gal dished out 27ft round, AG vinyl, 1 1/2 HP Matrix power flow pump, Hayward pro series s-210T sand filter, 26 yrs. old with aluminum ladder, use TFP kit to test, fill with city water.
    We live in central PA 16866 Summers are short. 80-90 avg.
    Jul 2016
    4
    The problem started with the crystals this yr. I went to the pool store and i complained
    of green algae. So they sold me Swimtrine Plus and I added 1 qt. The following day i added socket and the pucks. The crystals started to grow right away. The Swimtrine put .1 of copper in the water. They said not to worry because algae doesn't like copper. PLEASE EXCUSE ME, I'M NOT A WIZ ON THE COMPUTER, AND I CAN'T SPELL. THANK YOU FOR YOUR TIME!!!!!
    Mod note: merged your two threads asking the same question together to keep the answers together. pooldv
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: white crystals forming on ladder, HELP!!!!
    I'd recommend getting your water tested for calcium.
    May 2016
    Clermont, Florida
    27
    How about your calcium hardness levels? I suggest you getting that tested somehow.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Get some of it and pour a little acid on it. If it fizzles and dissolves then it is calcium scale. More here, Pool School - Calcium Scaling
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP Frannieb
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2015
    Raleigh
    357
    And don't add any more copper products to your pool.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jul 2016
    4
    Thanks, will try.
    Thank you
    OK, Thank you
    Jul 2016
    4
    fc 5.5
    cc clear
    ta 80
    cya 55
    ph7.6
    ch 212
    cooper 0
    Went to the pool shop and got the ch levels. So what do you think, is it calcium scale?
    Thanks for your input.
    SW Indiana
    9,199
    Quote Originally Posted by Frannieb View Post
    fc 5.5
    cc clear
    ta 80
    cya 55
    ph7.6
    ch 212
    cooper 0
    Probably not scale then, but check with the muriatic acid as described above.
    You can't trust pool store results. You said above you had .1ppm copper and now you have none. It doesn't go away, so one of those tests is wrong.
