Results 1 to 7 of 7
Thread: Timer recommendation
    TexasHeatWave's Avatar
    Jul 2016
    Cypress, TX
    14
    Can any of yall recommend a good timer for a Pentair 1 1/2hp pump/filter? The timer that I recently bought just isn't going to cut it so unfortunately I am going to have to shop around for a new one.
    27'x52" Yorkshire Metal Frame Pool (19,324 gallons). Pentair Dynamo 1.5hp pump/22" Sand Dollar Filter (250lbs).
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Timer recommendation
    Intermatic T104 will turn on and off the pump.
    Intermatic T106 will change speeds if you need that too.
    Mark
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    340
    i just have an intermatic t101. with 3 different settings so that it turns on and off at different times of the day.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    I use an Intermatic GM40AV, to cycle my Pentair 1-1/2 HP, 2-speed pump on low speed. I occasionally use high speed by just switching at the pump. Great timer, but very tiny non-finger-friendly controls; I use a plastic pointer to move trippers and on/off/auto switch.
    To automatically time operation at both speeds, both an on-off control and a speed-switch control are required. Wiring the T106 to change speeds requires rewiring the motor's power cord.
    Note: the GM40AV is rated for 1HP, 16.0FLA at 120V; my pump nameplate says 16.6FLA, so I put the circuit on a 15A breaker to protect the timer just in case increasing filter-loss wants the pump to draw its full amperage.
    I really like that the GM40AV has captive trippers.
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Jul 2016
    Cypress, TX
    14
    Thanks y'all for the recommendations. Can any of these be plugged into or are the all hard wired?
    chayne's Avatar
    May 2016
    340
    I know the t101 has to be hard wired.
    Charles
    Coleman 16'x48"
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    GM40AV must be hardwired. Before the GM40AV, I burned out a Woods plugin style in about two weeks.
