Results 1 to 14 of 14
Thread: DE entering pool
    Jul 2016
    Dewitt Iowa
    2
    DE entering pool
    I have a Hayward Perflex Ec40ac that is shooting de into the pool after you regenerate the filter. It does it for about 20 seconds each time, then it clears up. Does anyone know where to start when it comes to fixing it? Thanks
    38,361
    Re: DE entering pool
    Welcome to TFP!!!
    Sorry for the slow response.
    I have no experience with those bump filters, but do recall hearing of similar issues. Honestly, it does not surprise me much since you are knocking all the DE off the fingers and then turning on the pump to recoat them, so something might be able to get through the fingers before the DE coats them.
    You could always tear the filter apart and closely inspect that there is nothing damaged inside.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP Nmac54
    Solar Blanket, Well Water, Borax Added. 68
    Usually cracked tube sheets. Second most common is torn fabric on fingers.
    Support the site
    Jul 2016
    chester ny
    18
    I'm having the same problem with my EC 75.. Replaced Diaphragm, top plate and a few suspect fingers. Have taken it apart and inspected every finger.. Still not working right. The only thing left is the bottom plate. Bought a used assembly on Ebay for $100.. Going to swap it out.. If it works, it was the fingers. If not, I'm filling it in.
    Older in ground oddly shaped pool 24,000 gallons gunite
    Hayward EC 75 De filter w/ fingers
    no multi port valve
    38,361
    A lot cheaper to replace the filter than to fill in a pool
    Jul 2016
    chester ny
    18
    swapped out the whole filter unit with one I bought on Ebay.. Same issue... I'm at a loss.
    no multi port valve
    38,361
    What do you mean by filter unit? Do you mean a whole new filter? Maybe you are not seeing de and are seeing dead algae?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    When you say you have the same problem is yours also shooting DE into the pool for around 20 seconds after you regenerate ??
    jdudge, just an FYI. The OP hasn't come back but it's still better to start your own thread instead of hijacking someone elses. If he does come back it's sometimes very confusing trying to figure who you're advising to do what and what they've already tried.
    Jul 2016
    chester ny
    18
    Quote Originally Posted by Kiss4aFrog View Post
    By the whole unit I meant the finger assembly.. Yes.. same problem.. a bloom of dirty water, algae looking cloud shoots into the pool. The filter just isn't filtering like it use to. Pressure remains at 10 or so when it's operating.. Never builds.. Water remains cloudy..
    no multi port valve
    38,361
    Is there any bypass valve that could be leaking?
    Jul 2016
    chester ny
    18
    No bypass.. It's not a multi port valve..
    Although, I didn't check the backwash valve... Next on the list...
    no multi port valve
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Have the fingers themselves been replaced? If not have you tried soaking the fingers in a dishwasher solution then soaking them in an acid bath?
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    Dewitt Iowa
    2
    I ended up just replacing the de in the filter and that seemed to clear the issue up for now. Did I fix it or just mask the problem until the de starts to get clogged again?
