Thread: Checking in- maintaining FC
    May 2016
    Lansdale, PA
    6
    Hello! I am new to BBB this season--yay! I think I am getting the hang of it, and our water has never been clearer consistently, but I am having trouble figuring out how much bleach to add on a daily basis. I test every day, ok, maybe every other day- sorry. And things come out fine, so I leave it alone. I would like to get into a routine of adding a little bleach each day to maintain, but that has me hung up. I leave it because it's consistent for 2-3 days, but then FC drops off to 1, and I add a decent amount of bleach all at once, according to the chart, then it happens again. I feel like the chlorine runs away when I'm not looking. I've never had a problem with ugly looking water, though. How do I get it to level out and maintain? I'm just trying to see where I stand now. On another note, the water is now really sticky. Anything I can do for that, or is it because I messed something up? Thank you!!! Have a great day!
    PH 7.6
    FC 12
    CC .5
    TC 12.5
    TA 100
    CH 325
    CYA 60-70- I couldn't call it!
    Above ground 24 foot round, 4 feet deep
    Michromatic filtration
    Newbie to BBB this season
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Checking in- maintaining FC
    Are you saying you raise FC to around target (8), it stays at ~8 for a few days and then one day it's 1? That doesn't sound right, that's either testing error or bad reagents.
    Maybe it might be good to keep a log of every time you test and add, to make sure you aren't testing less often than you think.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    30,419
    I assume you are using PoolMath for your dosages, correct?
    1. Calculate the amount of chlorine it will take to raise your pool 3 ppm.
    2. Test your FC (record it) and then add the calculated dosage.
    3. Do the same thing the next day
    4. Do the same thing the next day and then test....you should be at your original FC + 3ppm (it will vary depending on a lot of factors but this should get you close.
    May 2016
    Lansdale, PA
    6
    Thanks for helping me. I am confused because when I tested with the small chlorine test kit, I got a reading of about 6. It's so hard to tell! When I did the drop test, I got the 12.5, but it's only my 2nd time with that test. So, yes, it could be my testing errors. I guess I need to test every day at exactly the same time to see what's going on. If CYA is at 60-70, am I supposed to stay at FC 8? That seems so high. I am so pool store trained that 8 seems crazy high. I did take water to pool store to test 2 weeks ago. I had a chlorine reading of 9-10 at home, and they got 3-4. Also, do you test for CYA every day too so you know what your FC should be?
    Thanks, and sorry for all of the questions!!
    Thank you! Good advice. I am still no expert with the FC drop test, so I always get concerned that I'm wrong. I hate to base it all off of my test, which could be incorrect.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    1. Just use the drop test. The "yellow drops" test isn't accurate enough.
    2. Yes, CYA 70 = Target FC of 8.
    3. Stay out of the pool store
    4. CYA shouldn't change that much from day to day if you are using liquid chlorine, I test mine once every week or so, some people go a month. If you have lots of rain or splash-out you might want to check weekly.
    May 2016
    Lansdale, PA
    6
    Thanks, Mr. Bruce! I appreciate your help and your time! You gave me excellent advice and set me in the right direction!!!
