Thread: In-line filter for skimmer hose vacuuming
    May 2011
    PA
    38
    Question In-line filter for skimmer hose vacuuming
    When I open my pool, and when my automated cleaners break, I fall back on vacuuming using a 1.5" hose through a skimmer port. Which quickly clogs my pump's little prefilter.
    Is there a hand-vacuuming filter, roughly as coarse as the one my pump, I can put between the vacuum hose and the skimmer to catch big debris so I don't have to stop and open the pump every minute to clean its filter?
    (This seems like an obvious accessory to me, but I've spent time searching and come up empty so far.)
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: In-line filter for skimmer hose vacuuming
    I know what you mean, I had the same issue. Actually split my pump basket before I knew what happened.
    This is what you seem to be looking for:
    https://www.amazon.com/Hayward-W560-...yward+canister
    or this (I have this one, gets pine needles too)
    https://www.amazon.com/W530-Capacity...yward+canister
    Dolphin E10 Cleaning Robot.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Check out the pics on PoolSchool....scroll down to "Leaf Canister" Pool School - Visual Encyclopedia of Pool Equipment
    I suggest you use this, or the skimmer basket itself to avoid risking a clog in your pipes. A skimmer plate cover will go right over your basket so all you have to clean out is that and nothing should be getting to your pump basket.
