Thread: What to use for protection under an above-ground pool?
    Swenny's Avatar
    Jul 2015
    MN
    6
    So I've seen a couple of posts about this specific question and it seems like everyone has a different answer. I currently have an 8 mil, 20x20 heavy duty tarp that I was going to use instead of the one that comes with it. But then I see other posts about a Gorilla pad, insulation panels, sand, etc. I have clay dirt if that matters
    1. So what would your ideal setup be and why? I'm thinking insulation panels, taped with Gorilla tape at the seams, and then rounded off about 6 inches longer than the diameter of the pool. Maybe put the pool tarp over the insulation? But rectangular panels under a circular pool sounds like a math nightmare, heh
    2. Also, if you use pavers under the legs, I assume the height of the pavers should be the same as the insulation panels?
    3. Thoughts of what to use around the base to cover up the panels/tarp/etc. to make it look less cluttered?
    Thanks everyone for all the help!
    Intex Ultra Frame 20' x 52" AGP (28339TT)
    8,600 gallons, city water
    Sand filter, 1,600 GPH pump
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: What to use for prtoection under an above-ground pool?
    When I put in my parents pool 30 years ago which is a still a standing Doughboy pool, I used sand as a base. We have trees all around it so the sand shifted over time as roots from the trees grew under it. This caused divets to form and eventually roots right under the liner. The liner still lasted a good 12 plus years. We finally replaced the liner and used the Gorilla type padding that was bought at a pool store. This is the way to go in my opinion. Very nice and even and no root problems. The pavers should be flush with the ground for the posts not even with the padding. You should also consider the wedge coving for the b0ttom inner edge of the pool. Just my 2 cents . Good luck! I should note that this was a metal frame pool an Intex may need the pavers set differently.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2009
    SW Wisconsin
    518
    I bought a used 33 foot round AGP. It had the old liner. I cut the bottom of the old liner out and after I had a level, compacted surface, I laid down the old pool liner, and then sand over the top of that. and then pool and new liner on top of that. Been that way for years now!
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
