Results 1 to 8 of 8
Thread: can above ground pool cleaner be used in ground pool?
    Jul 2015
    oakville
    17
    Hi
    I have a question, like this above ground pool cleaner
    Zodiac Ranger Automatic Above Ground Pool Cleaner - Walmart.com
    can it be used in ground pool? my pool is a in-ground big pool, I need a cleaner. This one is on sale in local store. I wonder whether I can use it or not,
    thanks for your help.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: can above ground pool cleaner be used in ground pool?
    You can but you will probably not like it. That looks like a kreepy krauly. Gets stuck. You get what you pay for. Better of saving for a better cleaner in my opinion.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2015
    oakville
    17
    thanks banditig,
    I know. However, as I know, a better cleaner is too expensive. This one is around $100. Others cost like 600 - 1000 . This is why I have to choose this one.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    It should help your cleaning. Just check on it every so often. I dont think it will do your steps or walls.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    It really depends on a lot of factors. I have a Ranger and it is great for light debris, but it gets stuck on the ladder, and an acorn will bring it to a dead stop. If you have a sport type pool with little variation in depth and very light debris such as a few leaves it will probably work. If you have heavier debris like acorns and pine needles or a traditional inground with a deep end then it won't work.
    If you are looking for a suction side cleaner you might want to check out a Baracuda MX8 or a Hayward Pool Vac XL.
    Love TFP? Become a
    TFP Supporter!
    wjr75's Avatar
    Jun 2013
    IL
    836
    I have used this cleaner on my parents above ground pool that I installed for over 20 years and highly recommend it. It uses the return line and has a sweep bag that picks up all the large stuff and the finer stuff gets mixed up and gets filtered out eventually. Your skimmer will still work getting the surface stuff. Maybe a little cheaper than a robot which I have no experience with since I have a Polaris 280 on my in ground pool which rocks. It's $177 on Amazon. Polaris Vac-Sweep 65 6-130-00 Pressure Side Automatic Pool Cleaner for Above Ground Vinyl Pools
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    It migrates to the deep end and stays there
    22,000 gal Cardinal Oasis 36x18 IG Vinyl
    Pentair IC40 SWG Sand Filter 1 1/2Hp Superflo pump Single Speed 3450 RPM
    Build date 9/25/15
    Taylor K-2006 with Salinity
    City water for fill
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    ... or the shallow end and stays there...
    Suction side cleaners are notorious for "patterning", circling the same corner of your pool and never going anywhere else and the skimmer doesn't work while the cleaner is in use. I've had a Kreepy Krawly and two Barracudas and they were all the same. Save your money. Buy a robot.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
