Thread: Testing and balancing
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    We had complete fill on our Finest Finishes (Gemstone) Radiant Fusion plaster last Friday. I have tested a couple of times but did not add anything as the pool had not been turned over to us until just yesterday. I tested last night but was too late to get any chems to add.
    I retested this morning:
    Air temp 81
    Pool temp 88
    Salt cell reading 2998
    14800 gallons (based on pool math calculator)
    pH 8.2
    FC 13
    CC 0.5
    CH 200
    TA 70
    CYA aprox 60
    According to pool math I need to add 18oz MA, 329oz calcium chloride, and 20oz stabilizer
    If I understand what I'm reading correctly, I add the MA to a bucket of water and pour in front of a return (with the pump on high), wait about 15 minutes (?), broadcast the calcium chloride across the deepest part of the pool (in my case the middle), and put the stabilizer in a sock in a skimmer basket.
    The stabilizer makes me nervous. I did the CYA test twice. It could be 70 but I'm not 100% certain. I just don't want to overdose on the stabilizer and have to empty any water from the pool to lower it.
    That's ALOT of calcium chloride!! I found it at lowes but I didn't buy enough. I only have 80 oz so I'll be heading there shortly to get more.
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Testing and balancing
    Had to re-read your post as you say the Salt cell is reading 2998 but in your signature there's no mention of having a SWCG
    You'd be good in the 70-80 range. It's good to do a little second guessing but in the end you need to trust yourself. If you wanted to be overly safe and conservative you can always add the stabilizer in two parts, testing before you add the second half.
    "If I understand what I'm reading correctly, I add the MA to a bucket of water and pour in front of a return (with the pump on high), wait about 15 minutes (?), broadcast the calcium chloride across the deepest part of the pool (in my case the middle), and put the stabilizer in a sock in a skimmer basket. "
    Yes (15 to 30min), yes and yes. I'd give it 15 before adding a second chemical but 30 to make sure it's mixed before re-testing.
    If you knead the sock you'll get the stabilizer to dissolve a lot faster. Just depends on if you're in a hurry or you have a bad case of OCD like me. Either way you should still give it about a week after the sock is empty before retesting.
    Solar Blanket, Well Water, Borax Added. 76
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Perfect, Kissafrog!! Thank you! And thanks for the pictures! That helps a bunch
    Ill get the SWCG added to my siggy. Didn't realize I missed it! Thank you again!
    Denise-TFP Guide
