Thread: Dropping below recommended free chlorine level
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Using Pool Math, I should maintain between 4 and 8 ppm Free Chlorine. Say my Free Chlorine drops to 3ppm using the Taylor K-2006 10ml test, do I need to slam or will I be alright? I'm not talking about a heavy bather load, just a typical, hot, summer day.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    30,421
    Re: Dropping below recommended free chlorine level
    These are not black and white situations. 4-8 is a suggestion.
    So, Don't let your FC fall below 4 ppm in the first place and if you do anyway, get it back up to 4 or better and you will be fine.
    In short, absolutes don't work as there are so many variables.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Sometimes it doesn't take much to drop below the minimum FC to develop a problem- particularly when the weather is really hot. Try and keep your FC up at the higher end of your target FC, test daily and always make sure that you have enough chlorine at all times.
    If you're not sure, you can always perform an OCLT and that will tell you whether you will need to SLAM.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
