Results 1 to 9 of 9
Thread: pH Test
    May 2016
    Atlanta, GA
    89
    pH Test
    I currently use the Tatylor K 1000 test, which came in my TF-100 kit, to test my pH. Is there a more exact test available where I can count drops??? I find it very difficult to match the colors when the shades of pink aren't even close to the test shades. Thanks!
    14.5'x32' irregular shape Pebble Tec SWG pool; 12,000 gal; Purex Triton Tagelus Sand Filter; Pentair IntelliPh Ph Controller
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: pH Test
    If the shade of the liquid is lighter than the lightest one, or darker than the darkest one on the vial, you're too low or too high. In that case, use PoolMath to figure a dose from the highest or lowest (whichever the case may be) pH on the vial to 7.4-7.5 and dose then retest in an hour and repeat until you get in the correct range of 7.2-7.8.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jun 2014
    15,056
    Re: pH Test
    Unfortunately there is no drop-based testing for pH. It can be a bit tricky at times. Best to find a neutral-colored background to hold your comparator view to. Some like a white piece of paper or wall. For me beige walls work best. Everyone's eyes are a little different. The more you practice and adjust pH up & down you'll begin to separate levels better.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,235
    Re: pH Test
    +1 to the comments from JesseSchmidt.
    Some people hold a white paper plate or piece of paper behind the comparison block. Holding it up to the sky also works well with the colors. No drop test as far as I know.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2014
    Hope Mills, NC
    567
    Re: pH Test
    I bought a pH meter, but you need to check its calibration before every use. No big deal, just keep a gallon of distilled water in a dark closet, set the meter to 7.00 and then test the pool water.
    Got it on Amazon.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,472
    Re: pH Test
    Interesting. Did you do some side by side testing and expected drop testing when adding acid? I see a few $40-50 PH meters but most are over a hundred and way up. Maybe the cheaper ones are getting better. Or maybe the better ones are getting cheaper.
    30,413
    Re: pH Test
    I always find this VERY helpful
    the colors going from low pH to high pH are....
    yellow 6.8 and lower
    yellow orange 7.0
    orange 7.2
    orange red 7.4-7.5
    red 7.6-7.8
    red violet 8.0
    violet 8.2 and higher
    Jul 2014
    Hope Mills, NC
    567
    Re: pH Test
    Quote Originally Posted by pooldv View Post
    I do still check with the drop test and the results are very close, as long as I check the calibration.
    I have this one at $17.50...Amazon.com: Pocket Size pH Meter with ATC and Backlit LCD, 0.05pH High Accuracy, 0-14 pH Measurement Range, 0.01 Resolution Handheld, Measure Household Drinking Water(Red): Home Improvement
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    Jul 2015
    Central Valley CA
    1,107
    Re: pH Test
    That one from Amazon is the one I have as well, it is almost always right in line with the k-1000 I would guess it is with in 0.1, variance I calibrate it once a week or so. On occasion (once every couple of weeks) it does get totally stupid and tell me the pH is 8.7 or some other ridiculous number and there seems to be nothing I can do to fix it but strangely when I try again the next day it is back to normal. Other than that quirk I like it over the comparator only only use the Tf-1000 on occasion as a double check.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
