Results 1 to 9 of 9
Thread: New Build - Plaster Issue
    Jul 2016
    Texas
    5
    Evening All,
    This post will be void of any pictures for the time being, but I will get them added tomorrow along with technical specs of the pool. I had a general question regarding new plaster and remedies. First issue, when the plaster was shot on my pool, the weep holes were still weeping quite a bit. Now that the pool is done, where the weep hole wept, and around the bottom drains, the plaster is discolored from the rest of the pool, plus there is a "bubble" of plaster that is higher than the surrounding area. The second issue is that when the plaster crew began to fill the pool, they ran two hoses into the pool but did not restrict or soften the flow of the water so the plaster ending up being rough and pitted/divots with the hose just laying on the plaster to start with. Plaster company sent a man out to try and remedy what he could. He had a "bug sprayer" with acid and sprayed the pitted areas and smoothed them out some, but they are still pitted and now it is discolored from the original pool color and the discoloration from the weep holes. In essence, three different shades of plaster in the pool. Finally, they are spots in the pool that I do not think they hit with the acid wash as the pebbletec is rough. Rough enough that as I swam up to my toddler who was on a bench, I placed my hands on the bench and coasted in, my finger was cut by part of the plaster.
    I have expressed my concerns and dissatisfaction with PB in person, by phone/email. Was told that they will fix it but recommends to wait until after pool season since technically the pool works and we have been swimming in it. Now to my questions about remedies. I was told that they would either be looking at doing an acid bath or draining the pool and doing the acid wash again. My concern with an acid bath is that I would have to trust that every square inch of the plaster would get brushed adequately, correct? With the acid wash, they just redo what they already did. Any concerns that after with either of those, that the plaster will be a different color than what I ordered?
    Other than the issue with the plaster, I have been mostly pleased with the PB. If they get the plaster fixed, will be 100% satisfied with the product. As mentioned, I will get pics and specs uploaded tomorrow but wanted to get started on my questions. Wish I saw this website about 2 years ago and studied hard before I had the pool built. A wealth of knowledge on this site. Thanks in advance. If wrong forum please advise.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: New Build - Plaster Issue
    Did you register your warranty with the plaster mfg? Wet Edge, Pebble Tec or whomever? I would file a claim with them and get them involved.
    See if this helps, Diagnosing Pool Plaster Problems
    Jul 2016
    Texas
    5
    Signature test
    Hope this is right
    IG; 22,000gallons; Hayward equipment; 2hp 2sp Tristar pump; 525 ft2 cartridge filter; gunite; Stonescape plaster; 3 led lights; pro logic P4 with Aquapod remote; inline chlorinator; ozone generator
    DFW, TX
    24,468
    I just checked your show sig box. Make sure it is checked, lower left of text box. Once it is checked on each device it will stay checked.
    More here from NPT on new plaster start up.
    Overview | National Pool Tile Group
    Jul 2016
    Texas
    5
    First picture will be the pre-ground breaking smoking of a brisket. Low and slow.
    DFW, TX
    24,468
    Nice!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    I'm already hungry. That pic didn't help. I hope they resolve the plaster issue to your satisfaction. It doesn't seem like a problem that an acid bath or acid anything will resolve. Interested to hear their proposed solution. No issue with having him do it after the pool season. They will be more focused then anyway. Just get the proposed solution(s) in writing now for reference.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2016
    Texas
    5
    Re: New Build with Plaster Issue
    Alright here goes. This post will hopefully be build pictures and "final" pictures. I will do a supplemental post with pictures trying to show the discoloration.
    Digging. We had lots of rock. Its a play pool; 3.5>5>4 and they hit rock at 3 ft.
    Next, we had some rain
    Cannot find the picture of the rebar or gunite in process, but here is post gunite
    Some rock work
    OK flagstone, with a shot of the tequila table in the background
    Deck pour, exposed aggregate
    Post pour
    Almost full
    Full and running
    Light show (if the link works)
    Hope this is right
    Jul 2016
    Texas
    5
    Now on to the discoloration. It's easier to see in person, especially before the sun gets up too high.
    Here is the weep hole post plaster, but pre acid wash
    This picture is where the weep occurred. Kinda hard to tell by the picture but it is the light area right in the middle
    The discoloration circle around the main drains
    Hope this is right
