Thread: Yellow mustard/Cloudy/unbalanced pH
    Jul 2015
    Northern IL
    42
    Question Yellow mustard/Cloudy/unbalanced pH
    Ok... So we had yellow mustard algae. The water was cloudy, there was yellow climbing the walls, and spats of yellow "gunk" throughout the floor of the pool. We pulled the stairs out and cleaned and scrubbed them. We slammed the pool for about 11 days (continuously vacuuming and scrubbing) and there was still yellow going up the walls and the water was still cloudy. My husband purchased "yellow out" from Leslies. He raised the pH to the recommended level and used the "yellow out". Within 24 hours the yellow was gone but it was still cloudy. So we continued to SLAM for about 4 more days until the water was clear and the overnight FC test was achieved. The pH was low so we raised it. Within 2 days, the pH was low again. We raised it again. The water became cloudy again and there are spats of gunk (can't tell the color) on the floor again. And the pH is low again. Any ideas or suggestions? Do we need to SLAM again first, then worry about the pH? Starting to feel lost.
    15 x 30 above ground, SunRunner sand filter, SunRunner 1.5HP SPL Pool Pump
    TFTestkits, CYA Chart, Recommended Levels, SLAM, OCLT, Posting Photos
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    Re: Yellow mustard/Cloudy/unbalanced pH
    I'm not experienced with Yellow Out, but here's the MSDS for anyone else who comes along: http://www.yellowout.com/pdffiles/MSDS.pdf
    Here's two articles you might find handy in the meantime...
    Pool School - Mustard Algae
    Pool School - Defeating Algae
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2014
    15,008
    I would also recommend sharing a full set of test results and perhaps try to upload a pic or two of this yellow stuff you are seeing. It may help the crowd here as we advise you better.
