Results 1 to 8 of 8
Thread: 2 week vacation - Float + pucks?
    Jun 2016
    Manchester, MI
    5
    Hi all, I'm on year 4 of our intex 9x18 and I use 10% bleach for daily maintenance. Water is great this year, had one algae bloom early on but quickly slammed it and have been great the last 6 weeks.
    However, we're leaving on a 2 week vacation this weekend and I don't want to return to problems. The pool holds ~6200 gallons and I'm running the intex 3000GPH sand filter. I plan to run it 8-12 hours per day while we're away.
    I purchased a chlorine float and a bucket of 3" pucks. How many pucks should I place in the float? Should I just fill it (holds 5) and put it on half flow setting?
    Thanks!
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: 2 week vacation - Float + pucks?
    At the bottom of PoolMath you can see what those pucks will add to your pool.
    A lot of folks who know they'll be away at times run their CYA lower than normal to allow for the rise from vacation use pucks.
    Another option is to bring it up to SLAM level, cover it for the 2 weeks, and hope for the best when you return. If problems arise you know what to do
    Have a great vacay!
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Quote Originally Posted by Change View Post
    Thanks!
    Sent from my 831C using Tapatalk
    Welcome to the forum!
    What is your current CYA level?
    Five 8oz trichlor pucks will add 27ppm to your CYA, and provide about 44ppm FC. I don't use pucks so I'm not too sure how slow they dissolve.
    If this were my pool I would bring it to shock level, float some pucks based on my CYA situation, & cover to minimize FC loss.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Manchester, MI
    5
    Thanks folks!
    CYA was at 35 yesterday. I don't keep it up high as I typically add a few ounces of bleach daily for maintenance.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP Change
    How big a pool is it ?? Any chance you have a neighbor or friend you'd trust to do some testing and treating ?? Or even just a simple "blind" addition occasionally based on your past usage ?? That full water testing kit can be very intimidating but having someone get a sample in the pH/FC tester and adding 5 drops isn't all that hard. They wouldn't even need to do pH as all you're looking for is not coming back to a green monster !!
    If you find someone, hook them up with this site and we can help them with any questions while you're away.
    Please add your pool and equipment info to your signature as outlined here: Pool School - Getting Started
    Solar Blanket, Well Water, Borax Added. 68
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Those pucks take a long time to disolve. I tied my floater with fishing line so it stayed in the middle of the pool so as not to bleach the liner. Went on vacation for one week and still had little bit left in floater.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jun 2016
    Manchester, MI
    5
    FYI, back from vacation and the 5 pucks in the float worked perfectly with the pump running 12 hours a day. Crystal clear.
    May 2012
    Montville NJ
    545
    Glad to hear it. I normally run my pool up to SLAM levels, and then add a floater on the lowest setting with two pucks in it when we go away for a week. They don't even dissolve all the way. The CYA added by maybe a total of 3 pucks a year in my pool is mitigated by spash out, rainfall, and lowering the water at closing.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
